Question about Nintendo Wii Console
Wii remotes will not stay on
I turn on the wii remotes and the blue lights flash across the bottom then immediately turns off. I have the rechargeable battery packs in all three remotes. I tried to sync all of them but when the back cover is taken off to hit the reset button the battery pack comes out at the same time.
    Problem Solver:
  • 15 Answers
1. Press the Power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
Posted on Dec 16, 2008
I haven't played my wii in a while and have just plugged it all in and my controllers are not working. They don't seem to be charging in the docking station, their individual docks are not lighting up...
Yes they should light up blue when they are charging.
Double check and make sure your docking station is still plugged in and turned on.
Most Docking stations are third party accessories, meaning, they were not manufactured by Nintendo. Some of them do not work very well.
If all else fails, remove the rechargeable battery pack from the Wii Remote and put regular AA batteries inside of it. The Wii Remote should work just fine.
Personally, I prefer to use rechargeable AA batteries rather than charging packs or docking stations. The charge packs/docking stations just never seem to work as well as they're supposed to. The rechargeable AA's work great and they're much more versatile since they're not limited to use in the Wii.
Apr 02, 2011 | Nintendo Wii Console
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
I had been using my Wii fit without any problems until I got (1) a rechargeable battery pack and (2) Wii fit plus. Since then, I don't get very far until the blue light on the balance board starts flashing...
the rechargeable batteries have a rating system, for how long they last.
a battery with 850mHa will last a far shorter time than 1 with 2500mHa rating.
and non rechargeable batteries have a much loger life span than all rechargeables.
Also rechargeables are 1.2 volt instead of 1.5 volt and will aleays run down alot quicker.
Feb 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii remote doesn't come on. Blue lights don't
Thanks for using FixYa!
If the blue light on your Wii controller doesn't light up, its possible that it ran out of battery charge. If you think your battery is fully charged. try to buy a set of disposable battery and see if they will work. If they do work, it means your rechargeable batteries have gone bad.
Have a great day.
-HotRatchet
Jul 28, 2009 | Nintendo Wii Console
Wii remotes blinks several times but doesn't work.
you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
Jul 21, 2009 | Nintendo Wii Console
Wii Problem, the remote
make sure a combination of the 4 blue lights at the bottom of the remote are on (but not flashing, mind you). if they're not, this means that your wii remote isn't connected to your nintendo wii system yet. if when you press a button and none of the lights turn on at all, this means that there are no batteries in your wii remote. if it flashes, this means its trying to connect to your wii system. you might have to troubleshoot this a little bit. try to aim it at the bar that recognizes the wii signal (a separate piece that comes with the wii system).
hope this helps ;-)
Apr 04, 2009 | Nintendo DS Lite
Reprogramming wii remote
Okay, on the front of the wii open the door where you'd put in an SD card, and take the battery covers off the remotes so you can access the reset buttons on both the console and remotes. Then press the red reset button on the wii and then within a second or two press the ones on the remotes. This should connect your remotes to your wii.
Mar 17, 2009 | Nintendo Wii Console
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
523 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
