Question about Sony CDP-CE275 5-Disc CD Changer
Sony PMC-R35L "no disc" message
When I put a CD in, it often spins it round, then tells me there's "no disc", and won't play it. Some CDs work fine; it seems to be newer ones that won't play. Sometimes I can get it to work by opening and closing the lid a few times.
  • Sony Master
  • 19,396 Answers
That is usually because of dirty or defetive lens.
Try first using a len cleaner , like the ones here.
If this does not work it will be necessary to take apart the unit and accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
Posted on Dec 16, 2008
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
Aug 16, 2009 | JVC KD-S640 CD Player
Compaq presario 700us will play cds wont play dvds
Try to put your laptop always on flat surface. Uneven base gives angle to the already tiny clearance space for the disc. Could be that the DVD disc run coz its finer, it will spin much slower than CD disc.
Hope i give you some good observation.
Mar 29, 2009 | HP Compaq Presario 700, 700A, 700AP,...
One more Time CD Jukebox Skipping
The fault is one or the other unit unless you have some sort of physical drag on the CD. There is a problem playing copy CDs too. Some work some dont.
Jan 04, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have a problem with my CD player
hi no1angel4u, there seem to be a dirty lens issue.try clean it with a lens cleaner cd its not much of a hassle.have a nice time.n hope your prob gets solved nice n quick.
raj..
May 11, 2008 | Audio Players & Recorders
Pioneer DVR-111D doesn't read CDs/DVDs, discs don't even spin
I've deviced DVD-RW drive but not display with my computer. tell m..
Apr 21, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Disc tray does not come out
as techman said "the old" carry with cds inside problem" yes you most have one cd inside thats the problem but letme tell you something is a problem for a cualify tech becouse to remove that cd you have to brake apart the hold cds carrier...good luck
Aug 02, 2006 | Onkyo DR-C500 Multi-disc DVD Player
Sony CDP-CE275 5-Disc CD Changer Logo
623 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
