Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Behind plastic screen looks to have dust on it
How do I take the plastic or plexi glass screen off the front of the TV so that I can clean the back of it? Is there any special clips I have to unhook? I didn't want to force anything.
  • Bradley Schuldt Mar 20, 2007
    OK, I just tried that, but I feel like I am going to break or damage the frame of the screen. I can't find a spot to put the screwdriver comfortably between the shield and the clips, would this be located in the corners? Sorry, I looked on Mitsubishi's web site for the owners manual, but the page doesn't load the manual up.
    President:
  • 3,130 Answers
That front screen is what Mitsubshi calls the Diamond shield. Every set is differant but easy to do. Look carefully at the top and the bottom or the lrft and the right, fr clips that run the entire lenth of the top and the bottom or the entire lenth or the right or the left side. They bsimply snap into place. Mitsubishi says to gently insert a small screwdriverbetween the diamond shield and one end of each on of the two clips and gently pull off the clip. Good Luck
Posted on Mar 20, 2007
  • Larry  Dillon
    Larry Dillon Mar 20, 2007
    The only other thing would be for your future use of a downloaded manual to explain how to disassemble the TV set or to make adjustment to, still alot less expensive then calling out a service tech, go to http://www.servicemanuals.net/results.as... Download the service manual and then you know for sure what to do when and where. Good Luck to you.
Hi, I have an Hitachi 42PD9700 plasma TV. When the TV is off you can see a mottled/patchy area on the top right hand side of the screen (this is still visible when the TV is on if you look closely). This...
Same problem. Gray clouds INSIDE the external (plexi)glass of the screen.
I guess either:
1 - Screen collection dust or some electrostatic phenomenon.
or
2 - Some coating peeling off.
1 may be solved by dismounting and cleaning.
Any solution you know about ?
Sep 22, 2011 | Hitachi Televison & Video
I have a Hitachi projection color tv and I cannot get the color adjusted good especially the red. Can you help me?
U know how to solders?Ur convergence it dead,need it replaced parts,by buy convergence kit.Tries Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My color is off on my whole tv i have a 52''projection toshiba cinema series the old big style and was wondering how to adjust the colors so they match up
Sounds like what was wrong with mine! Take the remote and hit menu, then scroll to the Video Adjust button, then adjust the "convergence" or the color tone, brightness, contrast etc. My repair man did this and it helped get the picture much more life-like. He said over time they get out of line and just need a few adjustments. He just charged the $50 house call. Good luck, hope you can fix it.
Dec 11, 2009 | Toshiba 50H81 50" Rear Projection...
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
TV appears blurry, and when using the remote to solve remote and buttons on tv are not allowing to re adjust colors for a clear pictue
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Nov 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I install/adjust color lamps on a Hitachi 51UWX20B rear projection tv
Nov 22, 2009 | Hitachi Televison & Video
Every thing on the tv is mostly blue
Nov 20, 2009 | Hitachi 51G500 51" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Hey
remvoving the screen can be a chore there are several t20 screws thaR AttCH the screen or the front bezal that contain the plexi like screen. there is a small plasic gromit or clip at the bottom of this that makes is difficult to remove. usally u have tor remove the entire front panel and control panel. i have learn as a tech to remove by leaning the screen forward from the top then pull out getting back on even trickey
Feb 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
