Question about BonJour Turbo Cuisine Handheld Blender
Need parts for a Bonjour Bar-B-Que Chef hand held blender. The shaft seems to be an easy replacement, but without the info on where to get parts, i can't proceed.
What is the difference between a mixer and a blender?
Kitchen appliances will and always will be an essential part of our life. Whether you are a culinary chef our a Permanent house chef :P Hand Blender, Food Processor, Stand Mixer and juicer mixer grinder these appliance will always be a part of your life. With these appliances you can tackle various kitchen chores with an ease; saving you an ample amount of time.
here you can know more
KitchenAid 6 QT Mixer
Oct 17, 2016 | Blenders
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
I have a bamix M200 hand blender & the shaft does not turn although the motor is working can you help?
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
May 21, 2010 | Bamix Deluxe Handheld Blender
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Aug 14, 2008 | Philips HR1358 Handheld Blender
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
BonJour Turbo Cuisine Handheld Blender Logo
26 people viewed this question
Top BonJour Blenders Experts
eyecam
Are you a BonJour Blender Expert? Answer questions, earn points and help others
