Question about Dell Inspiron 6000 Notebook
Flashing battery indicator
The battery indicator keeps flashing even though the battery is showing compeletly charged. The flash pattern is four quick yellow/amber flashes then one green then four quick yellow/amber flashes. Anyone know what this indicates. The manual says an overheated battery could be the cause, however, after most of the day unplugged with the battery out it still does the same thing. Thanks Jim
  • Anonymous Mar 22, 2014
    light flashes whether just on battery or connect to power source
    Scholar:
  • 135 Answers
It means you need to replace the battery. My wife's Inspiron did the same thing. Here is a link to someone else with the same issue, as well: http://west-wind.com/WebLog/posts/365.aspx I recommend third-party batteries from a quality source. They are quite good, and much cheaper than Dell-branded ones. Here's a source for both Dell-branded and third-party versions: http://www.batteries.com/index.asp?N=4294967279+4294967148+4294949141&Ne=25&Nu=p%5Fprodcode Plus, they are having a 20% off sale right now, using coupon code "FREE8"!
Posted on Mar 20, 2007
  • Joshua Muskovitz
    Joshua Muskovitz Mar 20, 2007
    I just noticed that the Dell (OEM) version is a 7200mah battery, while the batteries.com version is only 4800mah. It's probably worth the extra $15 for the bigger one.
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Battery light flashing
Common problem, usually associated with bad diode in the alternator. If battery is good, your alternator needs diodes even though it still works.
Mar 05, 2014 | 2006 Ford F 350 Super Duty
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
My battery light flashes red then green then red and so on even though its plugged in. The power indicator says I'm fully charged. What doed the flashing red and geen mean?
Try removing the battery and just use the AC adapter. If the laptop functions normally then you have a problem with the battery charging circuit . Either your battery is defective or the circuit that charges it is defective ( meaning the system board).
Aug 02, 2011 | Dell Latitude D500 Notebook
The battery indicator on my laptop keeps flashing unusually
Try to upgrade the bios you can download it on the support site of dell which is www.support.dell.com
ERNZ
Feb 05, 2010 | Dell Latitude D510 Notebook
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Is the lightening bolt supposed to flash orange? The battery will not keep a charge at all, so I have to keep it plugged in all the time. Does the orange flash mean I may be in danger of losing files, etc....
The orange flashing lightening bolt is confirmation the battery does not charge. It is not an indicator of any other hardware failure.
You can remove the battery if you find the flash annoying. The laptop will be lighter without the battery too!
Sep 21, 2009 | Dell Inspiron E1705 Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Electric light flashing
This indicates that your battery isn't functioning properly or is going bad. You need to replace the battery. Bateries are batteries, some are better than others and some wear out faster than others, even though they may be the same brand, eventually all batteries need replacing.
Jun 20, 2008 | HP Business Notebook 530
Dell Inspiron 6000 Notebook Logo
656 people viewed this question
Alun Cox
