Question about Dell InspironTM 1501 Notebook
Using a seperat numberpad for laptop
I have a Dell inspiron laptop, which have an "integrated" numberpad, that activates when you activate Numlock. I have also purchased a seperat numberpad, which also needs numberpad activated obviously. That arises some problem as I would like to use both the numpad and the letters on my laptops keyboard at the same time. Is there some way I can "deactivate" the numpad integrated into the keyboard on my Dell?
  • cwaldman88 Feb 25, 2009
    I have the exact same problem. I had a five year old Dell Inspiron laptop and I did not have this problem. Now I have a new vostro 1510. I just called Dell to ask how to fix it. I talked to Melody in the Phillipines for 43 minutes with no solution. She finally said it can't be done. I guess I'll have to constantly turn my num lock on and off so I can type an m, j, k, l, u. i. o.
    cwaldman@fusz.com
  • Anonymous Mar 29, 2009
    I bought a Dell Vostro 1510 and cannot use seperate number pad without using the number lock button constantly. I have also been on the help line in the phillipines for 1 hour and 45 minutes. No resolution this is why we bought 3 vostro 1510s very inconvieniant
    GTK
Some usually keys don't type [keys-67yuhnm]
I would guess that you have the NumLock activated.
Aug 16, 2011 | Dell Inspiron 2500 Notebook
Want to know how to undo FN Hotkeys: i.e., FN Esc. How may I reactivate screen after I put it to standby, 0r FN F1 when in Hibernate mode. Please notify how to properly activate and DEACTIVATE...
Trying using the "numlock" key it should undo the Fn hot keys. If your notebook is in hibernate state, using the power-up switch on the notebook will activate you notebook. This will ask you for a password, if you have been using one to logon to you notebook. The FN+F4 or F5 will toggle between a blank screen and a display.
Oct 06, 2010 | Dell Inspiron E1705 Notebook
I am trying to connect my laptop to the TV and would appreciated if someone could share information about connection details My dell inspiron 501 laptop has only the VGA port. The lowest resolution that...
Your dell should pick the TV up as a monitor if you have the VGA cable connected. The vga cable has a blue color on the TV but on the laptop, the color of the port is usally brown or dark in color. Windows should pick up on the new device and enable it. The Dell has an Fn key combination to allow you to toggle through the integrated / external monitor choices that you would have with two monitors active, that being clone both desktops to both monitors, extend the desktop from the laptop to the TV, use only the tv and turn the integrated off, use just the integrated and leave the TV off. The key combination is: Fn + F8
Jan 12, 2010 | Dell Inspiron 1501 Notebook
How do i turn off my blue keys on my inspirion keyboard
if the number lock on the keyboard is activated, then press Fn + Numlock to turn it off
Jan 09, 2010 | Dell Inspiron 1501 Notebook
Can't activate wifi key on inspiron 9400. fn f2
Try to uninstall then re-install the Dell Quickset from the Drivers and utilities disc.
Oct 29, 2009 | Dell Inspiron 9400 Notebook
Must hold function key down.
Hmm...first, is your "scroll lock" key lit up? if it is, you activated the number key pad for your laptop. if fn + scroll lock doesn't work, try re-installing the operating system (xp or vista) although it may be a pain :(
Jun 13, 2009 | Dell Inspiron 1501 Notebook
How do i activate and lock my Fn keys
Unlike previous models, The 1545 has no imbedded Numeric Keypad, so there is no NUMLOCK option.
For numerics, you will have to use the numbers above the QWERTY row.
SCROLL LOCK was also eliminated from the 1545 keyboard (Legacy item, seldom used)
If you need a numeric keypad and/or Scroll Lock, then an external keyboard may be an option.
Mar 25, 2009 | Dell Inspiron E1505 Notebook
Dell Laptop - Keyboard "Fn" is causing problems!
I think it is not the Fn key but the NumLock that is activated. Look for the key labeled NumLk , this is the number lock. Also check if the light on the notbook with a number (usually number 1) is on. If it is on, yo must deactivate the numlock by pressing it again. It works in toggle mode. Sometimes the numlock is activated together with the shift key, sometimes with the function key.
Jul 06, 2007 | Dell 0Y3740 Keyboard
Dell InspironTM 1501 Notebook Logo
381 people viewed this question
Alun Cox
