Question about Dryers
Gas dryer don't heat, pilot ok
It's a gas dryer mod no. 110.72622100 ser. ML4209795. It start fine, I can see the pilot turning on, The thermal sensors are ok
  • Dryers Master
  • 8,220 Answers
The ignitor is coming on so that means you have power to the gas assembly. Next the flame sensor should shut down the ignitor when the bi-metal inside it bends from the heat. This kills power to the ignitor, which allows for the power to activate the coils. The coils snatch open the gas valve and allow for ignition. The raw gas hits that screaming hot ignitor and ignites into a glorious flame, raising the temperature inside the drum. While that flame is on, the control thermostat is monitoring the heat within the drum. When the temperature gets to a round 140 F then the power gets killed to the gas assembly by the control thermostat. If all of that seems to be happening for say, the first time, then suddenly the ignitor comes on then shuts down and no flame comes out, then you have weak and intermittant coils. Replace these puppys:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
Testimonial: "I do just that and it have been working great. THANK´S"
Had a flood in the basement. THe electric motor works by there is no heat. Turned on the main and cutoff valve to the dryer started the dry it tumbles just fine but still no heat. Don't think...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | GE Dryers
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445 Dryer in heat cycle starts and runs 10 to 15 minutes then motor stops, after about 2 minutes motor starts back on it's own, operator doesn't have to do...
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Nov 19, 2009 | Kenmore Dryers
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
No heat
If electric pad heat element, if gas ck the gas supply line (make sure gas is on). could also be bad gas valve/pilot igniter.
Aug 09, 2009 | Dryers
Dryer will not heat. Mod: 11066652500 Ser: MS2302035
If your dryer is electric, it's most likely a thermal cut-off or the heating element. if it's gas, it's probably the thermal fuse. i do lots of these each week. 90% of the time it's what i just explained. good luck :)
Jul 03, 2009 | Kenmore Dryers
Dryers Logo
99 people viewed this question
Top Dryers Experts
Marvin
Marvin
