Question about Homelite Mighty Lite Lawn Trimmer
Replace a flexible curved shaft
I have a Trim N' Edge 25cc trimmer and the flexible curved shaft snapped at the housing end. I can get the flexible shaft out by removing the saft from the engine, but I can't figure out how to remove the housing & eyelet peice from the shaft housing. Is the housing and flex. shaft all one unit or is there a trick to remove the housing (trimmer head) so I can replace the flexible shaft?
  • Anonymous Jan 23, 2009
    same
    Scholar:
  • 76 Answers
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Posted on Jan 05, 2009
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
IT STARTS BUT TRIMMER PART WONT TURN
Disconnect the two halves of the shaft. It should be pretty easy. Inspect the drive cable to make sure it hasnt snapped. Also make sure the cable is inserted into the female half. Its a square shaped cable that spins and drives the string trimmer head.
Jul 24, 2016 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Edger blade quit turning
remove and inspect blade for damage. if all is well check flex shaft conection, may have damaged the inner flex shaft or the ends to the flex shaft
Sep 10, 2012 | Craftsman Convertible 25cc Curved Shaft...
How to replace the lower flexible shaft
Hi enriquemon,
To remove the drive shaft, loosen the clamp that is just above the protective shield and remove the set screw attaching the drive shaft tube to the trimmer housing. Remove the drive shaft and if you want clean and inspect for damage. You are installing a new one so it is not an issue. Coat the shaft with a high quality, multipurpose lithium grease. Make sure the ends of the shaft are properly located in the drive adapters when assembling. Depending on the amount of time it is used, the drive shaft should be cleaned and greased every year or two. I hope this is helpful to you. Any questions welcome. All the best and good luck.
Feb 19, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Broken or worn shaft flex. Motor runs and head moves a little with no power. How to remove shaft from housing?
First, about 4 Torx screws hold the end of the flex-drive tube to the engine housing. Remove those.Then, remove the throttle cable from the throttle plate shaft of the carburetor. If any covers are in the way, remove them.If the handle has a stop switch on it, then you will want to remove the wires from the ignition module (unless you can pull the tube out far enough away to access the flex drive. If the stop switch is on the front engine cover, then fine.
Once the tube is free and clear, just grap the end of the flex drive and pull it out. If you reinstall it, reverse it end for end and grease it well with lithium-based grease. Post back if needed.
Oct 25, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I strip the cable inside my lawn trimmer it would turn my cutter below. Is this something I can repair or must I take it to shop?
Hi and welcome to FixYa. I am Kelly. When you say you stripped the cable I am assuming that your talking about the flexible drive shaft. This can be replaced at home. However,.... ou did not state if this was a gas or electric model. At the moment I am assuming it is a 25cc Gas trimmer. To replace the flexible drive shaft the motor will have to be unmounted from the drive shaft housing. It will have 4 flat sides on each end that must mate correctly into the slots of the motor and the power head or you will not be able to re-mount the engine.
With a good model number I can provide you with a source of the replacment parts and probably what mounting hardware that has to be removed to change the fl;exible drive shaft.
Thanks for using FixYa.
Kelly
Jun 15, 2010 | Ryobi 15" Electric Factory Reconditioned...
How do I load string in a P2500 string trimmer??
Remove spool by firmly pulling on tap button. Cut two pieces of line (0.080) about 12 feet. Insert the two ends of the line into the small holes inside the spool. Wind the lines evenly and tightly on the spool. Wind the string in the direction of the arrows on the spool. Push the lines into the notches on the spool leaving three or five inches hanging there. Insert the two ends in the two holes in the hub. Align the notches on the spool with the holes in the hub and push it in until it snaps into place. Pull on the lines to release them from the notches.
May 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Fuel lines broke
Go to this sitehttp://www.upstateoutdoorpowerequipment.com/pages/parts/viewbybrand/11/Poulan.aspx
Jul 09, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Head will not drive. Can feel it slip between nut and motor.
inside the shaft is a flexible drive cord, at each end is usually a hex or torx head fitting that slides into a sleeve, theese can sometimes strip or even snap off and need replaced. remove one end of the shaft (either the engine or the spool) and the cord should slide right out easily. inspect each end for stripping and to make sure it didn't snap off inside the sleeves.
Sep 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
435 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
