Question about Whirlpool LXR9445JT Top Load Washer
Top Load Washer
My machine leaves the clothes to wet after spinning out and now there is a burning smell, It dosen't seem like the the tank is spinning fast enough to spin the water out. Is there a belt that needs to be tightened? Please let me know. The machine is only about 6 years old. Thank you.
    President:
  • 1,462 Answers
There is a drive belt from motor to drum but unlikely it needs tightening but possible. possibly a motor fault - try to identify where the smell comess from
Posted on Mar 20, 2007
No spin cycle - cloths soaking wet - motor runs continuously - hot burn smell
if the washer drains the drive cuppler it bad let me know if draing can walk you threw how to replace
Jun 24, 2011 | Roper RAS8445KQ Top Load Washer
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My maytag washer has a burning smell.
What model do you have.?It doesn't sound like it was spinning.A frozen pump would make the belt burn and it would leave some water in the tub .
Oct 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool LXR9445JT Top Load Washer Logo
120 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
