Question about Compaq Presario 1510 (White) 15 in.CRT Conventional Monitor
Overheating problem My notebook overheats and shuts down. The vents are clear. The tech I took it too said that the lamp is heating up and causing this problem. He offered no solution and I am not sure what he means by the "lamp". Does anyone have any more information for me about this? Is this a part that can be replaced? Thank you, Deborah
  • Deborah Reese Mar 22, 2007
    First things first...thank you for your response and suggestions. I will work through them and get back to you.
    *The model # is 1456VQLIT
    *The A/C adaptor is one of the things that gets very hot, as does the bottom of the laptop.
    *Laptop is sitting on a desk with nothing obstructing the vents.
    *Area around left side vent and air coming from that vent is very hot as well.
    I am wondering if the A/C adaptor could be part of the problem.
    Oops! The model # is 470036-657
Compaqs are notorious for having the heatsinks come loose of the processor. I have a Presario V2000 and after about a year it started to overheat. The fan worked overtime to try to compensate but it's just too small to overcome bad thermal contact. Problem is caused by the use of a thermal pad fromt he factory and flimsy metal tabs to hold the heatsink onto the motherboard. Eventually through normal wear the heatsink wiggles a little loose and you do not get good contact with the processor for proper cooling. Good news is it is pretty easy to fix. Mine was not very difficult to remove. BE SURE TO HAVE POWER UNPLUGGED AND BATTERY REMOVED! Just take all the screws out of the bottom of the laptop and you will see the fan and heatsink combo. There are some screws holding it onto the motherboard. Remove them and carefully remove the fan/heatsink. Carefully remove what is left of the thermal pad (grey square of rubbery stuff on the bottom of the heatsink). Apply a layer of "Arctic Silver" or equivalent cooling compound to the area where you removed the thermal pad. The arctic silver is better at transfering heat and will also help keep the contact sufficient since it is more of a fluid. Be sure the get the heatsink back on as tight as you can, but be sure not to warp or break the motherboard.
Posted on Aug 15, 2007
  • 624 Answers
Deborah67, To answer your question about what the tech was referring to with the term ?lamp? it was probably the florescent backlight that lights up your LCD panel. While that could be adding to the problem I haven?t seen one cause a laptop to overheat and shutdown by itself. Try a few experiments and let us know the results: -Try running with the A/C adaptor without the battery main batter installed. If it stays on longer or stays on then the battery or charging circuitry is part or the entire problem. -is the fan on the back of the laptop running just before the laptop shuts off? If it is can you feel warm air coming out? If not then that too could be the cause or part of the cause. -Try turning the LCD brightness down, if that doesn?t cause the computer to run longer than the LCD is probably not the major cause of the heat. -What type of surface is the laptop resting on? -How long does it take to overheat and what are you running when it does? -Flip you laptop over and give us the Model number listed there. That will give me more info about the processor installed. That along with the battery charging process generates much of the waste heat in a laptop.
Posted on Mar 20, 2007
  • tomj23 Mar 23, 2007
    With the heat you describe if the fan isn't turning on you may have found your problem. The external A/C adaptor is seperate from the laptop so really does'nt factor into this unless there are charging issues. Removing the battery will help figure that out. Let us know.
Computer shuts down after 10-15 min
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
May 13, 2013 | ASUS Eee 900 Notebook
How to resolve the overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
Apr 07, 2013 | HP G60-127NR Notebook
Compaq Presario 1700T overheats and shuts down
Mar 26, 2013 | HP Compaq Presario 1700T Notebook
Compaq Presario F767NR wifi overheating video card
Jan 29, 2013 | Compaq Presario F767NR Notebook
Overheating amilo
Jan 26, 2013 | Fujitsu AMILO Li 2727 Notebook
Suddenly shut down
Oct 30, 2012 | Dell Vostro 3750 PC Notebook
My acer notebook 1 keep shut down
Aug 25, 2012 | Acer Aspire One PC Notebook
Acer guet hot end shut down
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 02, 2012 | Acer Aspire 5315 Notebook
Overheating on Compaq Presario Notebook Model C501NR
May 18, 2012 | Microsoft Compaq Presario C501nr Notebook
Overheating problem
With all respect for the repairman, he must have been a bit confused.
The only lamp inside a laptop is the one behind the display, and when it overheats, the laptop does not shut down. The lamp blows and laptop keep working with no picture or dim picture on screen, that is all.
Most common cause for overheating on a laptop is the fan on top of CPU, if it is not working properly or not well adhering to cpu surface, then the laptop will turn off after a while.
When fan is ok,a faulty motherboard or faulty CPU can cause the computer to shut down, no lamp at all in all this, the repairman must have confused your laptop with a laser printer.
Here is a tool to check computer temperature and fan speed, click where it says SpeedFan 4.33. under download.
...if you cannot fix it by yourself I suggest changing repairman...
regards
Mar 19, 2008 | Dell Inspiron 2200 Notebook
Compaq Presario 1510 (White) 15 in.CRT Conventional Monitor Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
