Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Coffee beans empty
My machine starts grinding then comes back saying "coffee beans empty". It also has a faint smell like something burning. Is there some maintenance that should be done on the grinder or anywhere else that may affect this part of the process? Thank you
    Problem Solver:
  • 6 Answers
Try changing the beans to a different brand I had this same problem with the brands that were around $30 a kilo but not with the cheaper ones. They seem to clump together and not drop in to feed the grinder. It could be that you just need to adjust either the internal or external grinder settings also.
Posted on Aug 30, 2007
  • ken routley Jun 28, 2012
    hopper is filling with coffee but not processing
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
Coffee beans empty but not
Could Be one of 2 things, the grind is set too fine and the beans are not getting to the millstones, or there is something blocking the chute for the grounds.
Dec 31, 2009 | Gaggia Titanium Espresso Machine
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Funny smell when grinder operates. like burning rubber or something.
Open the bean chamber and vac out the coffee, then adjust grind to about 2 numbers coarser then try, if the smell is still there then you will have to clean out the grinder chamber by disassembling, and removing the object causing the smell.
Oct 08, 2009 | Gaggia Titanium Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Saeco royal cappuccino coffee machine beans container empty fault
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Oct 30, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
353 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
