Question about SanDisk Sansa e260 MP3 Player
I can't turn on my sandisk mp3 4g player?
I held the on off button, made sure the hold buttton is on and still unable to turn it on, any suggestions????
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
How start lighting pilot
turn switch at gas valve 2 hold buttton down 3 with button held down light pilot or push spark button 3 times and continue to hold button down for aleast 1 minute then let off button turn to on position
Sep 29, 2010 | Heating & Cooling
My sansa mp3 player will not turn on
This happened to me today, which was what brought me here. Also, when I plugged it in to recharge, my computer didn't even recognize it. The SanDisk troubleshooting said to hold up a power switch, which I didn't have, for 20 seconds. So I held the power button down for 20 seconds. (Much longer than the usual amount of time required to turn on). At first I thought it didn't do anything, but then when I pressed the power button again briefly, my SansaClip woke up, was recognized by my computer again, and in every way behaved normally.
Jul 10, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa e200 will turn on, thumbwheel is blue and SanDisk screen comes on, but menu won't come on. I have pressed and held the power/menu button down for app. 15 seconds several times to no avail. It is...
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Sep 27, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk E 250 unable to turn it ON
Make sure the hold/lock switch is not engaged.
Try switching between MSC and MTP Mode if that fails.
Otherwise:
-Tha Mp3 Doctor
Feb 18, 2009 | SanDisk Sansa e250 MP3 Player
Frozen?
Its easily fixed. Try this.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e280 8 GB MP3 Player
Try connecting it to a PC to see if the data is read/writable.
Oct 06, 2007 | SanDisk Sansa E280 MP3 Player
Sandisk sansa e250 only sandisk logo on powerup
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Again, select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
My Sandisk e2600 won't turn on...please help.
If you have tried rebooting it over and over and getting no where it sounds to me like you will have to format i'm afraid :(
Mar 01, 2007 | SanDisk Sansa e260 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
