Question about KitchenAid KEYS850LQ Electric Dryer
Kenmore HE3 gas dryer burning!!!
I noticed an electrical burning smell coming from the dryer. It smelled like it was originating from the front control panel. I removed the top of the dryer, removed the front panel and inspected the circuit boards. After isolating them I could tell the smell was not from them. I then removed the board that is on the side and above the drum. This board also smelled fine. The smell stays with the unit.Any ideas where this could be burning? It is an electrical smell for sure.
  • mjh10896 Jan 06, 2009
    My dryer also will no longer heat. It is about 9 yrs old. I took the front panel off and found TONS of compact lint. Mine seems like the origin of the "fire" is near the motor (this is where the charcoaled lint has the heaviest soot). I tested all fuses and the dryer does still run, just blows cold air.
    Help!
  • 53 Answers
Could be lint in dryer vent
Posted on Jun 06, 2017
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
SOURCE: I could smell burning from
kelvinator...must be 20 years old..but works really well, it's on the very rapid spin cycle at the very end I think that maybe something is chafing??
Posted on May 07, 2008
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • 2692 Answers
SOURCE: DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Posted on Jan 07, 2009
  • 74 Answers
SOURCE: bad smell in drum of washer
Unfortunately this is a quite general problem today as we are washing more and more in rather low temperatures. Gunk and slime packs up in the rubber gaskets and elsewhere in the machine, smells horrible if not kept under control.
There are a few things you can do.
1) The most important thing IMO is to make sure to wash at the highest temp at least once a week, 90-95 degrees Celcius.
2) Always leave the washing machine lid half open when not in use in order to allow the inside to dry.
3) A supplementary thing is to run an empty machine wash cycle once a month or so using bleach (chlorine) in the recommended dose for your machine. Use highest temp to maximize effect.
There is also some work that can be done with a rag, mechanically cleaning out the gasket and all accessible parts in the detergent compartment etc, however this may have quite limited effect. Worth trying nevertheless.
Other than that you c
Posted on May 27, 2009
Lg tromm gas dryer burning smell shuts off
Hello Debi;
My name is Peter. I am a retired field service appliance technician.
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Nov 20, 2014 | LG Dryers
I think something got passed the filter into the blower wheel (read some of the other questions and believe this is it; check filter light on and a burning smell was there when I tried to run it). I...
remove the top cover and control panel,then remove the front cover and the door and the blower wheel will be in the left lower corner in front behind the front panel
Oct 14, 2010 | LG DLE2514 Electric Dryer
SMELLS LIKE ITW BURNING
I highly recommend opening the dryer by removing the front panel.
Unplug the machine, remove the front cover and be prepared to vacuum out the lint build-up inside the housing of the dryer.
Also clean the exhaust duct of lint buildup too.
Sep 12, 2009 | Whirlpool Dryers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Electric burning smell from dryer
first check your dryer vent hole and dryer wall vent to make sure there not clogged with lent,most of the time that's what it is,let me know and we can go on from there-mike
Dec 17, 2008 | Dryers
How do I take off the front panel
At the very bad of the machine take out the phillips head screws which pass through an L shaped part (which is attached to the top) into the back of the washer. (the L part should stay with the top) Slide the top back about two inches and lift off. Remove dispenser drawer by pushing down on the center tab at the back of the dispenser drawer, then remove one screw behind dispenser drawer front and one screw at each upper corner of control from back side of control. Panel is still held by tabs across top. Be careful, as there are sharp areas here. Detach all electrical plugs from control, and it should be loose in your hands now.
Nov 20, 2008 | LG WM-2277HW Front Load Washer
Burning smell
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Burning smell and no manual
dont have a service manual for it but i can tell you thta in order to acess the inner workings heres what to do. First remove the filter assy and then the 2 phillips screws under the filter. the top should the pop up and you need to remove 2 5/16 screws holding the front panel on the front panel will then lift off allowing you acess to the belt and motor asy, belt part number 341241, and a 691366 for the idler/tension pulley assy. the burning lint smell is probalby form an excess of lint within the cavity of uint, if you find excessive lint build up checl your venting!!!!!
Nov 02, 2008 | Estate TEDX640JQ Electric Dryer
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
KitchenAid KEYS850LQ  Electric Dryer Logo
344 people viewed this question
Top KitchenAid Dryers Experts
Virgil Watts
Marvin
Marvin
Sal De
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
