Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
I have a fridgidaire quite 1 built-in dishwasher aprox 10 yrs old . Its not cleaning dishes sounds funny,and soap is staying in dispenser. Have any advice
  • 5 more comments
  • mondoandfrip Dec 27, 2008
    NOt washing dishes. Checked and the arms (bottom and top) are not spinning. Took motor apart and seems to be fine.
  • michael919PL Jan 26, 2009
    The pump motor seems to be spinning but the spray arms don't spin. The empeller looks fine and the holes in the arms are not clogged.
  • Dave Bruner Feb 15, 2009
    How do you check to see if there is adequate water pressure?
  • andi8982 Feb 16, 2009
    how do I replace the water pump as mine is doing the same thing
  • Dave Bruner Apr 02, 2009
    How do you check the water pressure on a dishwasher?
  • Anonymous May 22, 2009
    I have a similar problem... My fridgidaire is about 7 years old, lately it seems that the dishes are not clean at all (I use the tablet) it seems to go through all the cycles but the soap doesn't seemed to be dispense at a proper time??? when it's done, all the steam and everything is there but the dishes are still dirty... please help!
  • ttvu May 22, 2009
    the dishes are still dirty after the wash.. i read some solutions on this site, which is helpful...but how do i know if i have enough pressure for the arms to spin?
    another question is when does the soap dispenser suppose to open? beginning? mid? certainly not at the end... :(
  • 725 Answers
First check the wash arm ... check the holes in the wash arm . make sure that they are not plugged.
next check that the wash arm is moving . spin it to check that it is free.
next check that there is water pressure to move the wash arm... let me know
Posted on Dec 16, 2008
Fridgidaire pld4375rfc0 detergent dispenser not opening
Hi leeroyf - If the soap is not dispensing all the way out then usually the sprayer arms are not able to reach that area of the unit and door. I recommend making sure that the area is clean of dishes to try to prevent this issue because it sounds like something is blocking it and that the dispenser door is not stuck. Using the correct of amount of soap is also helpful. However, if problem proceeds then I suggest contacting a professional to move forward accurately since it may be having an issue with the wiring connections to dispenser and control.
Dec 03, 2012 | Frigidaire Professional Series 24 in....
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Wont clean dishes
Oppen it up manually for a few times Vitally
May 13, 2009 | Frigidaire 24 in. FDB635RF Built-in...
I have a Grohe dish soap dispenser that get clogged-? soap
Dilute the soap you use by 1/3 . this won't affect the soaps ability to clean, but it makes it easier on the dispenser.
Jan 16, 2018 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 04, 2008 | GE 24 in. Profile PDW7800 Built-in...
Soap dispenser won't open
make and model are critical there are so many different types of dispensers that it is impossible to help you without this info
Apr 24, 2008 | Dishwashers
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
233 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Oloyede Monsuru
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
