Question about Canon EOS Rebel XSi Digital Camera
Night and low-light specialty/experimental photography
As a fellow Expert on the site you caught my attention in the Expert's lounge, and I was curious as to what your expertise was on, and found some of your camera related solutions to be of a higher experience level than my own, and while I know a bit on the technical aspects as well as form and function of photography, I only recently bought and started using digital, and before that I did not have a great amount of experience with photography with film anyway.
Anyway, my request is for experience advice that you may have regarding night exposures, specifically with digital cameras (I have a Canon EOS XSi that gives me shivers on how much it outclasses my previous equipment), and also low-light experimental photography (specifically Macro in low light and also using closed apertures to decrease light exposure on shots)
I have three lenses, one is 18-55mm wide-to average perspective zoom EF-S, one is 75-300mm EF telephoto zoom, and the other is a 50mm EF lens.
I was told that due to the fact my camera uses a sensor which is .6 of the area of 35mm film, and the EF lenses were not made for digital cameras with a smaller exposure area, it magnifies the focal length of the EF lenses by .6, making a 75-300 lens into a 120-480. If you know whether or not this is fact or misinformation, please verify as well.
Problem: I have a macro adapter which I wish to use on subjects, and have a narrow field of view, thus a zoom lens is preferable - however, the 18-55 requires a very close subject but provides a decent DOF strictly in focusing terms, while the 75-300 lens allows a more distant subject but highly restricts the focusing depth, AND on top of all that there is very, very little light. While normally this could simply be corrected by using a tripod, increasing the aperture and decreasing the shudder speed, I have to do it by hand - the subjects are either inaccessable for a normal tripod, or require quick-setup to get the shot, meaning by hand and trying to get the correct focus to aperture compromise within five minutes in usually an awkward position, making hand-shake an issue. What would your recommended lens be, going in close and getting the largest area in focus (and hopefully limiting handshake) but also having a larger than desired shot, or using the 75-300 lens for short focus depth but better manuverability, as well as increase in hand-shake problems.
Second problem: getting night-shots to look as if they were at night. To my amazement, every time I do a night-shot and expose for the camera's desired "correct" exposure, it looks like early morning instead of 1AM. To compensate I've been increasing shutter speed, but that only seems to work to a degree. Also, I use the highest ISO speed (1600) in order to produce a grain effect as well as be able to lower the handshake issue even when I increase the shutter speed, since the shutter speed for a very dark exposure is still around 1/25th of a second. What I'm considering is whether or not increasing the aperture instead of increasing the shutter speed would produce better night-shots and just do enough bracketing to compensate for handshake or pack a tripod around to use as a unipod for stability.
  • 1 more comment
  • Dshack
    Dshack Dec 16, 2008
    I do almost all of my normal photography using manual focus, aperture and shutter speed. Needless to say I don't do much action photography.
    However, for the quick-macro shots (insects, dew drops, rain, paint drying, whatever catches my fancy) I care less about shutter speed and more about the aperture, and use AV - though on everything non-macro I use the lowest aperture setting possible under normal circumstances. It's part of my style, for whatever reason. Thus, I am unfamiliar with the effects it may play in a night-shot.
    As I shoot purely in RAW and make no exceptions I also have to process it - and it seems I'm as lazy about processing RAW files as I was about processing prints, but I believe I can get a few basic, unpolished images to my flickr account for an example.
    Thank you for the info on the sensor ratio multiplier, and also concerning the ring strobe - I've seen them but that was before I began photography and haven't thought of one since, but it would indeed be perfect to add light to a close subject while using a macro adapter/lens in photography.
  • Dshack
    Dshack Dec 16, 2008
    As it is, I only have miscellaneous shots, but the pile waiting on my harddrive is just begging to get some air.
    I dislike serving something before it is suitable, but I may as well, with the notice that I am updating it and currently do not have any exposures of note concerning my interest in this particular thread, but shall in a while.
    http://www.flickr.com/photos/art-oblique...
  • Dshack
    Dshack Dec 16, 2008
    Can you still post a reply, or has my rating the conversation locked/lost the query?
    Novelist:
  • 121 Answers
Hello, thanks for the compliments!
First, yes, the Digital Rebel series of cameras (my first DSLR was the first Digital Rebel, the 300D model) have a small sensor than a "full frame" sensor, which results in a "multiplicationfactor" or "crop factor" of .6. This is good for telephoto shots (yourtelephoto lens ends up acting like a "longer" and more expensive lens) but bad for wideangle shots.
For Macro, you need very bright light to have enough light to use a small fstop for needed DoF because even at the smallest fstop (largest number) your DoF will still be very small. This typically means you need to use a strobe. The strobe will help freeze the image so you can still shoot hand-held. For hand-held use look for a "ring strobe" that fits around your lens and lights the item in front of your lens.
Focusing is a very tricky matter when you are shooting in macro. Usually you go to manual focus, set the lens to manually focus at either infinity or the closest distance, then you "focus" using the zoom, rather than the focus ring.
For night shots, you need to change to manual exposure and adjust to get the exposure you desire. Your camera's light meter doesn't know how bright or dark the thing you are viewing is - to the light meter everything you point it at is supposed to be exposed to medium gray - an average value. It can't know that you want a dark shot to stay dark.
Here's how I do it. First, I bump up the ISO so I can take a fast shot, and I set the camera to AV mode. Then I set the lens to the widest aperture (smallest number). I let the camera set the shutter speed as I take this test shot, and look at the exposure. Then I determine if I want the shot darker and if so how much. Now I switch to manual mode - same aperture and shutter as the previous shot, and adjust the shutter speed faster to produce a darker image. When I have the right settings, then I adjust the ISO and as I adjust the ISO I have to compensate with the shutter. E.g. if I have a good exposure at ISO 1600 @ f2.8 @ 1/30, to drop to ISO 100 means I have to slow the shutter to 1/2 second. Now, I usually also want a smaller aperture (larger number). To go from ISO 100 @ f2/8 @ 1/2 second to f/16 is 6 stops, which takes the time needed from 1/2 second to 15 seconds. Obviously this means the camera needs to be on a tripod.
I can help more if you can give me a link to some of the photos you have taken so far so I can see what you are shooting, and make suggestions for how I would approach the same subject and situation.
Posted on Dec 16, 2008
  • jcdill
    jcdill Dec 16, 2008
    I'd love to see your photos - can you share your flickr account?
  • jcdill
    jcdill Dec 17, 2008
    I can post a reply, but I only see your first question and my first reply - none of the subsequent replies (yours or mine) which makes it rather hard to build on prior discussions!
I can't find the sub menu settings....ie if I set menu as scene. How do I find sunset, or night etc
am not an expert but this blog I found might be useful.http://www.natalia-robba.com/myblog/tutorial/time-lapse-photography-the-dos-and-donts/
Oct 21, 2016 | Cameras
Night Photography
Wait until the sun goes down.
In many ways night photography is just like day photography, except there's less light. With less light, you need a slower shutter speed, a wider aperture, a faster ISO, or a combination of all three. Or else you need to add light.
Just like day photography, the best camera settings (and other things) depend on what you want the photograph to say to the viewer.
You can add light by using the flash, car headlights, etc. The flash doesn't have much range; if you're sitting in the stands at a night sporting event your flash isn't going to affect any pictures you take of the action on the field. Another effect of the short range is that if you take a flash picture of a person at night, you're likely to have an almost completely black background. If you want something of the background to show, use the Night Portrait mode (and a tripod).
If you want to take a picture of a night landscape (or the night sky, with star trails) then turn off the flash. Put the camera on a tripod or other steady support and use a slow shutter speed.
If you're taking a picture of the full moon, then it's not night photography at all. The full moon is just a big rock under a midday sun, so treat it as such.
Nov 22, 2013 | Computers & Internet
Night focus maxxum 7000
First auto focus SLR. Does not focus well in low light. Put on manual focus at infinity setting on lens scale, and put camera on tripod and set the lens to something likeF8. Set exposure time to different settings and see which one works out best. You might also check your local library from one of the Kodak guide books (low light photography, etc.)
Oct 24, 2013 | Minolta Photography
I need instructions on basic usage
you can go to sites most of the Photography sites which give out free tutrials and know how on basic usge and photography tips sites like Digital Photography School (DPS) can be of help
hpe ould be of help
Mar 28, 2011 | Cameras
Experimental set up for wireless transmission
Yes it is possible to transmitt electrical power without wires, just not likely from your generator.
Go search for Nicoli Tesla on the web, he was a very smart fellow who did lots of work on this long ago.
Carl
Dec 08, 2008 | Coleman Powermate Premium Plus 6250W...
Videoing or taking picutres at night
This camera is not designed for use in extremely low light. The sensor needs ample light to record a clear picture. You can compare this to using different speeds of film and needing to leave the shutter open for a longer time during night photography with still cameras. Unfortunately, there is no fix for this other than buying a light to use with the camera...unless it has an infrared setting (but then, everything would be green)
Nov 07, 2008 | Vivitar DVR-550 DV Camcorder
Lounge
I understood Pierre , see my second post, unfortunately the lounge is monopolized by experts that want to expose each other solution in the hope to gain some favour or advantage (how?).
This situation became critic since I noticed there was a slight time delay and some expert was having premiums displayed earlier than other.
The fact, as alex explained me, was just a temporary system fault due to bigger work cue, but some expert thought there was a kind of hierarchy among experts and started a race in showing other experts' weaknesses.
I do not care much about rascal, but I considered the Finnish a better person, someone from my same legacy to say.
This with 5 inapps received today had driven me mad.
Well no probs, this is not real life, lets enjoy summer.
Nice to see you around by the way, hope to see Irish druid back.
Aug 16, 2008 | 2005 Datsun 210
Projection TV Expert Needed
I just posted a response for the Toshiba. If that doesnt help I will assist them to trouble shoot and get the set operating again. That other expert should be banned from here.
Jun 29, 2008 | Toshiba 61HX70 61" Rear Projection...
Low light
Yes that will happen if your camera is set for automatic.
Set your camera for manual by pressing the menu button.
You will have to tell it all of the conditions manually, such as ASA, lighting, and flash.
You can disable or control the flash by using the buttons located on the rear of the camera.
Jun 10, 2008 | Samsung Digimax L60 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
140 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
