Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Freezer OK No cold air coming into Refrig.
I HAVE A Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Jenn-Air JSD2789GES Side by Side Refrigerator the freezer is working well, however, no cold air is coming into the refrigerator side. There is no forst in the freezer and I have the temp set to the lowest setting. So what can I do to fix it and How??
  • 725 Answers
Check the evaporator fan if it is running then check the damper at the top is opening also the return vent at the bottom... if all is working then you need to check the evaprator is not pluger with frost... let me know
Posted on Dec 16, 2008
The freezer part is working good but the cooler side cools but not enough
the damper vent door between the freezer and fridge section isnt opening up to let cold air in from the freezer side to cool the fridge side,its behind a plastic grille near the top between the 2 compartments,there is also an evaporator fan near this and it also needs to be operating to move the cool air
May 24, 2011 | Jenn-Air JSD2789GES Side by Side...
Water not draining to pan when defrosts draining into freezer causing ice build up at bottom of freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Jenn-Air JSD2789GES Side by Side...
Hello...we have a JCD2289AT that is 6 years old approx...frezer and ice maker are working fine butr refrig seems to not hear a cold temerature even after setting to the coldest setting. I pulled the unit...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2010 | Jenn-Air JSD2789GES Side by Side...
Freezer seems to be ok. But refrigerator is not cold??? any simple fixes would be greatly appreciated
Somewhere in your fridge should be a fan that circulates air from the freezer section toi the fridge section. Chances are it is not running.
Jun 21, 2010 | Jenn-Air JSD2789GES Side by Side...
Water freezing on bottom of freezer
The defrost drain pan is plugged and not allowing the water to drain into the pan under the refrig. Remove the cover on the back wall of the freezer and clear the drain by flushing with hot water.
Mar 25, 2010 | Jenn-Air JSD2789GES Side by Side...
Refrigerator side doesn't keep things cold, just cool, despite having it on the coldest setting and the cold vent open between the freezer. The freezer is working fine.
Look on the back wall of the freezer for a ice buildup. If there is ice you have a defrost problem. The defrost timer is in the fresh food section inside the control panel.The defrost heater and defrost thermostat are behind the freezer back panel inside the freezer.
Also check the freezer fan. If there is no ice buildup in the freezer the freezer fan motor could be bad.
Nov 21, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Jun 07, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn Air side by side is not cooling
Check the compressor and see if it is running. If not it is the run\ start relay.
Apr 06, 2009 | Jenn-Air JSD2789GES Side by Side...
No cold air coming into the fridg
iF YOUR REFRIGERATOR SETTING IS HIGH, YOU NEED TO LOWER THE SETTING IN ORDER TO GET IT COLDER.
If you still have no air flow, there is a fan that blows cold air from the freezer to the refrigerator. The motor could be burned out.
Sqiudo
Dec 15, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
173 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
