Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave runs for two seconds and cuts off
The GE Profile JVM over the range microwave will only run for two seconds and then cuts off. We have unplugged for ten minutes and tried again but it does not reset. Code 8888 shows up after it quits running.
Any ideas.
  • 1 more comment
  • Anonymous Apr 09, 2009
    I have a GE Spacemaker Over the Range Microwave Oven model JVM1653
    When I try to use it, it runs for a couple of seconds and stops. I have to reprogram the clock to try to use it again. Sometimes I could get it to work, but now I can't get past a couple of seconds running time. apearson
  • jarutkowski Apr 09, 2009
    The microwave shuts down after running for a couple seconds. I've tried restarting it several times and once in a while it will work.
  • jetolar1 Apr 27, 2009
    Runs for a coupe of econds and cuts off. occasionally run like its supposed to. Also the clock disappeared.
  • GE Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
To prove this, you can unplug the oven, swing the control panel out and down, then plug it back in and run it for a couple minutes.
If it doesn't fail, it;s the magnetron.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Good luck.
Posted on Dec 16, 2008
What are the specs for GE JVM 1339BW002
All microwaves above the stove top are 30" wide . The only difference is the top to bottom measurement . Some are 15 1/2" in the back and some are more .
Feb 23, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
JVM 1790sk01
Cook using microwaves or convection in this stylish microwave oven that allows your food to be flavorful beautifully browned and cooked quickly .now your microwive didn't work .you should take it to fix .
home light bulbs
May 03, 2012 | GE Profile Spacemaker Over-the-Range...
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I am realtor. Just sold home with built-in over the range GE Spacemaker 2.0 microwave oven (JVM 2070). The three buttons on lower right hand side (vent, boost, light) are missing. You have to stick...
Yes. You can find handy exploded views and order parts by model number here.
To aid in disassembly, the service manual is HTML clipboard here.
Sep 07, 2010 | GE Profile Spacemaker Over-the-Range...
No heat
If the fan, lites, all work and appears to be running normal but just no heat, chances are its the magnetron that has failed. Sometimes magnetron will make a deeper noise if it has failed
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Thanks
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 02, 2009 | Microwave Ovens
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
266 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
