Question about Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 JAMMED
Whenever I get an incoming fax, the paper jams, any help?
In addition to what bhuggins said, remove the drum/toner unit, carefully remove the toner cartridge and look for scraps of paper stuck in the rollers on the drum unit. I had the same problem and cleaned the machine over and over. I never thought to check the drum/toner assembly, but when I finally did sure enough there was a little scrap of paper causing all my jams.
Posted on Dec 14, 2012
Clean the rollers, but also check the drum/toner. at the front there is a peice that breaks on occasion that will cause a jam.
Posted on Dec 17, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Just clean paper path and clean all roolers and specially paper pick up roller.by mian jee
Posted on Dec 16, 2008
Fax machine 2820 not working at all - just beeps no matter what button is pushed
check paper ....!! or ribbon toner is it inserted properly
hope if it helps
Apr 04, 2011 | Brother IntelliFax-2820 Laser Fax
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
Error message says unable to print on Brother 2820. It will not answer an incoming call but will transmit a fax. Machine is in almost new condition, barely used.
when you send a fax do you get transmission report? open back to see if there might be a jam, remove cassette to see if there is a jam. if these areas are clear of paper then you have a mechanical problem and it would have to be seen by a tech
Nov 14, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
Brother fax machine says back cover open and it is not open. Why?
This message comes up sometimes when paper is jammed inside. Remove paper thru back cover.
Mar 05, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
933 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
