Question about Canon PowerShot S2 IS Digital Camera
No pitcure camera turns on and works fine except the lcd screen is black when you look through the eye piece it is back. The pictures are also black
    Novelist:
  • 107 Answers
It sounds like your shutter has become stuck closed. Normally the shutter stays open while you compose the pictures and then closes when you hit the button to take the picture allowing the image sensor to record what it saw at that moment. If it stays closed you will not see any image at all, but the normal icons and text on your camera's display will still show. The same symptoms can also be caused by a failed image sensor, although this is less common. Freeing a stuck shutter requires disassembly of the camera and lens assembly. Check with your manufacturer for recalls and/or warranty support. If they cannot help you for free there are repair providers online who can work on your camera. David Millier Advance Camera Repair
Posted on Mar 23, 2007
I had this problem with my S2 IS and Canon fixed it for free. Their service receipt said it was a failed optical unit. The S1 IS model has a service advisory about CCD failures that Canon will replace for free, but the S2 IS model does not yet have a service advisory. Canon should add the S2 IS model to its service advisory immediately because many customers are experiencing this problem and according to online reports, Canon's repair policy is inconsistent. Some customers are being charged for the repair and some are not.
Posted on May 05, 2007
Everything works except the view finder. Both through the eye piece or the display screen,
hi,
If EVF and LCD screen not giving picture, check the change over switch inside the monitor hinges clean it with contact cleaner spray, if it is OK, open and check the circuit on the mother board,
Feb 28, 2016 | Canon ZR40 Mini DV Digital Camcorder
Olympus Stylus 7030- only a month old and the screen has gone black, but the camera still takes pictures and sounds like it is cycling through the pictures. The zoom lens works and the shutters still open,...
Hi There,
You say that everything looks fine except the LCD. If it's true , you will be able to take pictures right? so you try to take pictures and downloaded into the computer.
after this step we know what to do in the future.
let me know the progress.
Jan 07, 2011 | Olympus Cameras
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Cant take photos with my Kodak ZD710
check eye settting or its a fungus inside lens black screen is due to virus
Jun 18, 2009 | Kodak ZD710 Digital Camera
Cant take a picture although camera turns on
2 possible solutions. !. try using another SD card. if the one in the camera is full, you cannot take a picture. 2. Try another SD card for transferring, (and taking pictures) and try transfer of this card in another camera or reader, such as the one in photo print places.
Apr 13, 2009 | Kodak EasyShare Z612 Digital Camera
No picture on lcd screen only when taking pictures
Did you accidentally press the DISP or DISPLAY button on back (it turns the screen off to save batteries). If so, press this button again to turn your LCD screen back on.
Oct 07, 2008 | Canon Cameras
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Black screen
Assumed that LCD screen is black and what about Eye piece viewfinder? Does it show picture to you?
If LCD Screen is black, it means it has no back-light. check any button to turn back light on & off at LCD portion.
There can be an other reason of black LCD. a flexible cable which connects LCD and Camera circuits and it can be broken/ cracked/ out of order.
May 30, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Panasonic digital camera has black screen
CCD sensor faulty especially if you can play back pictures that were captured properly, but have a blank screen in capture mode. Replace sensor and camera will work fine.
Sep 12, 2007 | Panasonic Lumix DMC-LZ1 Digital Camera
Fuji S3000 wont take pictures
Check for corrosion or dirt in your cameras battery compartment.
Jun 04, 2006 | Fuji FinePix S3000 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
215 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
