Home | Canon | PIXMA iP1500 InkJet Photo Printer | Paper jammed. Remove jam...
Canon PIXMA iP1500 InkJet Photo Printer
Problem for Canon PIXMA iP1500 InkJet Photo Printer
Paper jammed. Remove jammed paper
By winkoei18 on Dec 15, 2008
Paper jammed.
Remove jammed paper and press the printer's RESUME button.
Solution #1
posted on Jun 03, 2009
Somewhat Helpful)
Ekse
Rank: Guru  Canon Expert Computer Hardware  Expert
Rating: 88%, 4599 votes
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP1500 InkJet
Questions and Unsolved Problems for Canon PIXMA iP1500 InkJet
Do you recommend Canon PIXMA iP1500 InkJet Photo Printer?
Answer
Answer
prints, but only every few lines. Those that print look normal, but in-between, they are faded. A... (More)
Answer
error 5100when trying to install
Answer
Printing is splotchy. The page starts off OK, then about halfway down (or 2/3 down), it starts to... (More)
Answer
how do you replace the absorbent filler on a pixma 1500
Answer
My Canon Pixma IP1700 gives me a message saying "the ink absorber is almost full . Contact... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA iP1500 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
