Question about Axsion Axion ACN6150 15 in. TV/DVD Combo
Axion 10" tv/dvd - dvd not working
Aion 10" tv/dvd - dvd not working - not recognizing the dvd - message is "No Disc" :o(
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
Dvd player doesnt play the movies
Try another DVD. If problem persists and it does not work with any type of DVD, whether recordeable burnt DVDs or original pressed DVDs then your unit is bad - either dirty lens or the laser diode is bad.
Sep 26, 2009 | Axion LMD-6708RY 7 in. Portable DVD Player...
Can i connect a tv tuner to my lmd-4702ru dvd
if theres an video input you can connect it purchase an digital box it can recognized almost all channel that available in your cable and antenna.
Sep 24, 2009 | Televison & Video
There is an error message on the TV screen that says "insert a playable disc", however we know that the dvd works fine in other dvd players.
Are you using a copy of a DVD? Not all DVD players recognize DVD's that are copies of the original.
Aug 24, 2009 | Televison & Video
TV connecting to portable dvd player
You should be able to hook into your tv with no problem using a audio/video jack available at any radio shack, you would tune your tv to either the select "video" channel or ch.3, your t.v. set should have no problem with the attached device.
Sep 07, 2008 | Philips 26PW6341 26" TV
Need AC Adapter
Hey kublat,
If you are looking for a replacement AC adaptor for an Axion DVD player, I would strongly suggest first checking with the manufacturer for more information. Typically if a manufacturer is unable to provide you with a replacement part, they may either have a list of aftermarket replacement parts that are compatible with your model or have a list of other retailers that currently carry their replacement parts.
Please keep in mind that the preferred method of contact for Axion does differ based on the location where you purchased the player. For most purchases, you can simply call Axion support at (909)-869-6600 or by visiting the company's support website:
http://www.axiontv.com/www/supporthome.asp
For models purchased through Radio Shack however, Axion has provided an alternate customer service hotline: (866)-571-9143.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 05, 2008 | Axsion Axion AXN6050
DVD player not recognizing disc
i have the same problem, i cleaned the laser lens with camera lens cleaner and it made it much better, not perfect, but, better.
Apr 16, 2008 | Televison & Video
Dvd component mal-functioning
Could it simply be your DVD reader is broken?
Jan 06, 2008 | Panasonic PV-DF2702 27 in. TV/VCR/DVD...
Axsion Axion ACN6150 15 in. TV/DVD Combo Logo
Top Axsion Televison & Video Experts
Marvin
Marvin
Are you an Axsion Televison and Video Expert? Answer questions, earn points and help others
