Question about White Sewing Mighty Mender WW100 Mechanical Sewing Machine
Loading the bobbin and adjusting the tension.
I was just given my mighty mender and it doesn't have a manual, How do I load the bobbin in it and adjust the tension?
  • 1 more comment
  • katina_l May 08, 2008
    I have the same problem - How do I load the bobbin?
  • jessichaotic Aug 31, 2008
    yeah, same here, how do i load it?
  • greenstonepo Oct 11, 2008
    do not have manual & do not know how to load bobbin
Loading the bobbin for this maching is fairly simple. First thread the machine. Then after placing the bobbin in the machine pull the thread out through the first notch and back through the second. (The end of the thread should be going in the direction of the little channel on the left side of the bobbin area.) Now what I did was make a loop with the end of the thread and pushed it under the casing below the needle. Then if your machine is threaded correctly you should be able to turn the knob on the right side of the machine so the needle goes down and comes back up once. If you've done it right the bobbin thread should come up in the correct spot.
Posted on Mar 15, 2009
Loading the bobbin is no different from another machine. there is a tensioner ON the bobbin. load from the back notch to the front as it sits in place.If the thread does not catch on its own, the problem is this!:the needle itself is not at the right height. as dumb as that is, it is not going deep enough to catch the loop. actually pull down on the whole need and its hardware. you will find the needle carriage is just held in by tension. I thought that was dumb, but when I got it correctly aligned, it works...The needle needs to be at the bottom as the "hook" below the bobbin passes by. To get that alignment is by virtue of pulling up or down on the needle.
Posted on Aug 15, 2012
Where can I purchase the power cord for the mighty menders sewing machine w100.. I got a used one but without the power cord
This is a bit unusual as it appears to have a power adapter a bit like a laptop. It you have the adapter, any good electrical shop will have the cord to it.
Product description If you are looking for a lightweight, portable, compact sewing machine for those everyday mending and sewing tasks, the Mighty Mender is it! This handy little machine offers important features such as free arm design, true locking stitch, 2 straight stitch lengths, built-in bobbin winder, drop-in bobbin, foot controller and more! It is easy to operate because of it's compact size, it can be used anywhere and conveniently stored when not in use. Crafters and sewers alike will find 100 uses for the Mighty Mender WW100. Accessories included are: an electric adapter, instruction manual, needles, bobbins, needle threader, and seam ripper.
it is pretty obscure
mighty menders w100 sewing machine spare parts Google Search
Jun 04, 2018 | Sewing Machines
The bobbin does not catch with the needle on the white mighty mender w100
It is most likely a timing issue. You need to take it to a reputable repair person.
Oct 11, 2014 | White & W-100 Mighty Mender Lightweight...
Mighty mender w100
here is a link for a manual for the machine,, the information about putting the bobbin back in the case should be in it
http://sewusa.com/Sewing_Machine_Manuals/White_Manuals/100_Instruction_Manual.htm
Sep 27, 2013 | Sewing Machines
Repair bobbin case on mighty mender W100
Did anyone ever figure it out? I can’t get it back in either. Got this for 10$ and the machine was brand new. Figured it would be good to start with but the thread keeps bird nesting on the bottom. Tried adjusting tension, rethreading.. now I just took case out to tighten screw for the bobbins tension and cant get it back in. Thinking about throwing in the towel and buying a better machine.
Jan 12, 2013 | White Sewing Mighty Mender WW100...
Need help with bobbin on w100
http://www.hammerwall.com/Download_Manual/70097/
here is the complete instruction book for your sewing machine hope this helps!
Nov 10, 2009 | Brother SE-270D Computerized Sewing...
For the White Mighty Mender W100 sewing machine, how does the bobbin thread come up to join the needle thread?
Same as with all machines essentially.......
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 30, 2009 | White Sewing Mighty Mender WW100...
Where can I purchase a bobbin for the Mighty Mender W100 Mechanical Sewing Machine
Well, here's an easy fix. It is either a class 15 or class 66. I would go to a local repair shop with your machine and they can try either of them . They are not real expensive.
Apr 18, 2009 | White Sewing Mighty Mender WW100...
Can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful oneb1934dc.jpg
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.76e4431.jpg as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
Mar 15, 2009 | White Sewing Mighty Mender WW100...
White W100 Mighty Mender Sewing Machine Instructions
I have the "mighty mender" instruction book you are looking for everyone !! Happy to help all you sewers out there!
Apr 10, 2008 | Brother SE-270D Computerized Sewing...
White Sewing Mighty Mender WW100 Mechanical Sewing Machine Logo
806 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
