Question about HP Deskjet 3915 InkJet Printer
Keep saying i am out of paper even though there is paper in the p
Help
  • Anonymous Feb 08, 2009
    is a deskjet 3915
    Novelist:
  • 180 Answers
Can you tell me what specific printer model is that?
Posted on Dec 16, 2008
SOURCE: Dell printer keeps saying to clear paper jam even though no paper
Went into Dell support and followed their instuctions on getting the cable back in line and in place
Posted on Nov 14, 2008
  • 3 Answers
SOURCE: its saying the paper tray is empty even though there is paper
the problem is with the paper sesor in the paper tray. It must
be under the tray lift mechanism.
This is located in the right front part of the paper tray.
Posted on Dec 01, 2008
  • 58 Answers
SOURCE: hp p1006 wont load/feed paper
Mine does the same thing. The solution I have used on several occasions is to load it as full of paper as possible without forcing it under the guides. Lift the lid to reset the jam function, then when it begins to try to print, push the top one or two sheets of paper into the printer. If it will grab them and print then it will be ok for the whole stack of paper. Adding more paper before it gets too low also seems to help.
Posted on Jun 05, 2009
freetek
  • 5568 Answers
SOURCE: printer keeps saying there is no paper even though
The travel of paper through the machine is timed and if the pickup roller is no longer as tacky as it should be, the paper may be arriving too late to allow for printing. Cheap 'copier' paper has a soft surface which can lose fibers over time that can cause the pickup rollers to have less grip on the paper too.
There is also the possibility of remnants of paper (or more often labels) that can delay the timely arrival or may be impeding the progress of the sheet through the paper path.
Posted on May 14, 2010
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
ADF Motor Assembly has gears which crack. Replacement of ADF Motor Assembly normally required. Compass Micro Inc sells this part. Part #: 2132225.
Posted on Jul 30, 2011
Keeps saying paper out cassette 1
Sometimes the rollers that take the top paper into the printer get a little worn or shiny and doesn't grip so well try helping it at the point when you hear it start to try and take the feed in by holding the top piece of paper and easing into the printer feed.
Mar 22, 2015 | Epson Expression Premium XP 820 Wireless
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Screen reads paper jam even though there never was a paper jammed. I tried turning the printer off and on but the same message still appears. Also the cancel ! keeps flashing even though I cancelled the...
Hello Sande.
Try cancelling the printer job via the control panel in Windows.
Also open covers, including the top flatbed half, to view the paper path.
There may still be a stray piece stuck in there somewhere.
Does this help?
Clive.
Nov 18, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
The register keeps freezing and then shuts off. it says that the till roll is not properly inserted although it is
Hi Leanne
check around the path that the paper goes through, look for any dust build up or small scraps of paper and blow out/remove and try again. Hope this helps.
Feb 17, 2013 | Computers & Internet
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
Its saying the paper tray is empty even though there is paper
Nov 18, 2008 | Brother MFC-8460N All-In-One Printer
Fax says Paper Jam but there isn't one!
After what operation does the machine report the jam. If it is trying to print something and the paper doesn't pull, then it will report a paper jam, even though the paper didn't move. If this is the case then the paper feed tire behind the toner is dirty. Cleaned with rag and rubbing alcohol.
Apr 08, 2008 | Canon FAXPHONE L80 Laser
HP Deskjet 3915 InkJet Printer Logo
77 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
