Question about HP (D9896-69007) Motherboard
Computer cuts off will trying to boot
I have a dell computer. I push the power button and it acts like it is booting... However it stops after 3-4 sec. and keeps doing this over and over until I finally unplug it.
  • 21 Answers
Your power switch is getting stuck. Clean it with an electric cleaner spray and your problem will be solved
Regards
Pieter
Posted on Dec 16, 2008
Dell Inspiron One 19 Black screen after dell logo boot up
Sounds like you have a video driver issue. See if you can boot from your "Dell Resource" CD or any other bootable CD disk. Power on the computer and tap the F12 key to get to the "Boot Selection Menu". Insert the "Resource CD" into the CD-ROM drive. Select "Boot from CD/DVD drive" from the selection menu. If the computer boots from the CD drive then you Operating System Software is the problem.
Mar 19, 2013 | Dell Inspiron One 19 All-in-One Desktop PC...
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
3 main lights turn on with AC or DC power then cut off and no boot.
Here is one of the simple steps to fix your issue.
Remove the battery and the ac adapter on the computer, then try to push the power button for about 10-15 secs. After doing so, try to connect the ac adapter alone, then turn the computer on. Check if still the same scenario. If still does, try doing the same steps again but instead of pushing the power button, Press and hold FN+Power button, this will allow the computer boot up to the built in diagnostics of the computer, run the diagnostics. If still the same, trry different ac adapter, if it works replace the ac adapter if still the same after replacing the ac adapter, contact Dell as it might be a Motherboard issue.
I hope this can help you.
Thank you for choosing fixya
Mar 04, 2011 | Dell Inspiron B130 Notebook
Dell T3500 with E139765 on motherboard. LED on motherboard is yellow & system will not boot up.
Try the steps given below and it should resolve the issue;
1. Turn off the computer - unplug the power cable
2. Press and hold down the power button for 1 minute with power cable unplugged
3. Release the power button
4. Reconnect the power cable and turn on the computer
5. Dell ought to boot in Normal Mode
Lemme know the results.
Regards,
Anirban Mazumdar
Dec 04, 2010 | Dell Precision T3500 Computer Workstation...
Vista computer will not boot 1 out of 3 times with linksys usb
Power off the computer.
Power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
You'll reach the system setup screen. Look for an option for BOOT. Disabled Boot form network and BOOT from USB. Save and exit from the system setup. This should do the trick.
Jul 30, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Computer will not turn on
Do you hear the hard disk spin up? is there a hard disk boot password configured? can you see a bios screen as it tries to boot? is the light on the power supply lighting up?
May 28, 2009 | Dell Latitude D810 PC Notebook
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Inspiron 1000 will not boot up.
Greetings,
The symptoms you described are normally common motherboard failure signs.
Try removing the ram and hard drive from the computer and then try booting the computer.
Oct 28, 2008 | Dell Inspiron 1000 Notebook
DELL DImension does not boot
Try removing your RAM handling by the edges, clean the terminals with an eraser and reinsert firmly. Reboot your computer. Make sure you remove static charges from your body by placing your hands on a grounded object.
Sep 03, 2008 | Dell Dimension 8200 PC Desktop
Dell Desktop
Have you tired holding down the power button. Other wise what model is this computer? And how far into the boot cycle does it get?
Jun 16, 2008 | Dell Computers & Internet
HP (D9896-69007) Motherboard Logo
137 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
