Back to:
Tags:
iLO -3200 32 in. LCD Television
Problems connecting computer to tv via dvi
posted by jsmythe on Apr 02, 2007
I can't seem to use the tv as a computer monitor. I have dvi video output on my computer and I've connected the tv to the computer using a dvi-d cable. However, the tv shows no signal and computer (as well as another laptop w/dvi out) are not able to detect the tv.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 11, 2007
Thanks for Trying (70)
brad325is
Rank:Apprentice Apprentice
Rating: 81%, 5 votes
Not sure if you have fixed your problem or not. When I hook up my pc to the ILO 32 HD...I ran DVI input for picture...you can also use HDMI if you like..I had a problem with sound and had to use a splitter and run sound into AV2 IN to get sound for some reason...your no picture...if you are getting a black screen, you need to set the resolution on your pc. VGA to 640x480 and SVGA should be 800x600 and XGA should set at 1024x768..most likely the last one is the one you need..and this is not a normal pc res....set your refresh rate to 60HZ. All this is done in the control panel/display/settings tab.
Also remember that you need to change your source on the TV to the proper connection to see it...ie component, HDMI etc.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problems connecting computer to tv via dvi:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
tv turns off by it self after 30 or 45 mins , must unplug...
if so what connections do i need to connect to my hp media...
picture stays on for 5 mins then turns off, i have checked...
i can only turn on can not change channel or use the...
Ok my remote was broken. Now i am trying to get to the av...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
