Question about Symphonic ST419E TV
Video Input The yellow, white, and red ports in the TV are for my DVD player and Games. Now, the yellow port doesn't work. I get audio but no video. On the back of the TV is a similar port and the audio works ther too but the video still doesn't work what could have happended?
    Novelist:
    Champion:
  • 275 Answers
Are you sure that the source is generating a video signal? It is extremely rare for both front and rear Video Input sockets to fail simultaneoisly. from your description, i would suspect the cable connecting the Viseo out of your DVD player / Video Game than the Video Input ports of the TV. If you have another cable, just try again with that. Or, try using the Red to red cable into the Yellow port, using one end at the DVD player and the other at the TV Video Input. If there is image, then it is confirmed that the cable is faulty, and you can get a replacement cable for a few bucks at any Video store.
Posted on Mar 21, 2007
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
I don't know which cables to use to hook up my sony plasma to a samsung dvd player, or how to hook it up.
Hi there. To enable your Samsung DVD player to work on your Sony Plasma, you will need two things:
1. The Power cable for the DVD player
2. The Audio(Red and White) and Video(Yellow) cables that should have been provided when the DVD player was bought. If ever these cables are not available, you may buy these at any Hyper Market such as Wal-Mart or a technology store such as Best Buy. These are called Composite Video and Audio Cables.
If you have the previous cables, connect the 3 Audio/Video cables to the back of the Plasma TV, it should contain the appropriate ports. Yellow cable(Video) for the Yellow port. White and Red for the Audio Left(L) and Right(R) ports. Then connect your power, turn the DVD on and switch from TV to other input which should display the Samsung Logo.
Please rate and comment, thank you.
Apr 14, 2011 | Video Game Consoles & Games
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I need help connecting sony dvp ns 300 to a jvc tv. I can't watch dvd at all, confused about the wiring where does it go?
The CD/DVD player has three output ports:
(i) Line out Video used to connect the yellow pin of composite cable.
(ii) S-video out use d to connect an S-video cable.
(iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV.
In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony DVP-NS300 DVD Player
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
I have a dvd player that I am trying to hook up to a sharp tv model number 25L-M100B. This tv don't have the necessary ports inthe back to plug dvd or anything up to it. It does have 2 in the front of
Hook the dvd player up to the front inputs usually a yellow and a red or possibly a yellow red and white depending if the TV is stereo or not.
Then on your remote, it the INPUT button and take it to "VIDEO 1" while your dvd player is on and you should get a picture.
Make sure not to mix the cable colors.
Yellow is video
White Audio
Red Audio
A lot of times there is only either white or red and not both. This is just Mono sound, it works, just not "stereo" sound.
Jun 01, 2009 | Televison & Video
Picture but no sound
Best to use the a/v cables.
Your player should have output ports for audio and video, on the ports that say output, plug the cable red to red, white ot white, and yellow to yellow.
Now, the cable going the back of the TV. Your choice, input1 or input 2. Just plug red to red, white to white, and yellow to yellow.
Now press the the input button on your remote until the picture and sound appear.
Apr 09, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Digix Manual/diagrams do not match my TV connectors
Simplest way. ++++++++++
If you have red, white and yellow on each match those and use a cable with 3 strands - red, yellow and white ends with RCA jacks. Use the setup key to get an onscreen display to set options.  Make sure they are the video/audio OUT on the DVD not in.
On your TV it's probably Video 1 or something like that - you can usually test this by putting the cables into the front of the TV. The TV remote might have some key like TV/Video to get to the Video input screen.  Make sure you check the video-in ports on the TV - not the video/audio-out.
Option if red is missing +++++++++++++++++ If the DVD player just has yellow and white then just connect yellow and white (it will be mono) on the TV.
It shouldn't matter if the holes are vertical or horizontal.
S-video +++++++ If both TV and DVD have S-video ports then connect those - they will give you better video than the yellow.
You will still need to connect red and white sound cables.
Jan 04, 2009 | Digix Televison & Video
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Symphonic ST419E TV Logo
132 people viewed this question
Top Symphonic Televison & Video Experts
SHARCNET-USA
SHARCNET-USA
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
