Question about Peavey Audio Players & Recorders
Cant record where do i plug audio out so i can record to a cd
    Genius:
  • 1,199 Answers
You need to go from the source outputs red/white to the red/white inputs of cd recorder! on recorder make sure you select analog input
this should fix ya!
Posted on Dec 15, 2008
I CANT RECORD CASSETTES ONTO A FLASH DRIVE
You can't. Cassettes are analog and the USB only recognizes MP3. The USB will only record off a normal CD or a CD with MP3s on it. It won't record other formats. The unit only allows to record from CD to cassette or from CD to USB. There are some cassette decks that will convert to MP3. Just do a search for "cassette to MP3 converter"
Apr 20, 2011 | Sony LBT-ZUX9 Shelf System
I cant get it to record my records from my sterio to the cd recorder
You might need to fill in something about how your records are being played, on what turntable, through what intervening electronics.
Is the level too low? You may need a PHONO preamp.
Are you using CD AUDIO recordable media? Must say "audio" or "music" on the disc.
Dec 28, 2010 | Philips CDR785 3-Disc CD Recorder
I cant find any blank cd that is compatible anywhere what is the exact cd that the unit needs i used to get the sound recording cds but u cant get them anymore
Any blank media with "audio" or "music" in its description should work. eBay has tons of them. Use "blank CD-r music" as a search.
Aug 18, 2010 | Philips CDR570 CD Recorder
How to record LP records to CD, using a 1978
All you need to do is connect two RCA plugs into the audio in of your laptop. The two RCA's go into a tape out of the recevier. If your laptop uses 3.5mm plugs for audio conections then get a 3.5mm plug to RCA plugs. See image below.
To record the music and convert it I would get Magix Audio Cleaning Lab, which you can pick up cheap on Amazon.
418f330.jpg The sound will then come out of your speakers on your computer and then you can record it with Magix and convert it with the software to any audio format.
Jun 18, 2010 | Bang and Olufsen Beosound 2000 Shelf...
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
When i put a balank cdr the recorer says wrong
Listen to it. Go out and buy "CD-R for AUDIO" or "CD-Music" blank CD's and it will cooperate. Home CD recorders are designed to reject data CD-R media for recording.
Jan 22, 2010 | Philips CDR775 2-Disc CD Recorder
Copying Audio Cassette to CD
Generally speaking yes. You could take the audio outputs from the tape deck and plug them into the audio inputs for any line in the DVD recorder. Then press record. Finalize it once your done.
A more professional way to do it is to record them back into a computer. If you have Windows Plus! Digital Media Edition installed into your computer, there is an analog recorder installed. All you have to do is plug the audio output of the tape deck into the microphone jack of your computer. Then it will convert them to mp3 format. That way you can use Windows Media Player to burn the CD with by creating a playlist. If you have Windows XP and you need Plus! it should be available at any computer store for around $20.00. Wome versions of Vista may have this feature included into the operating system as well.
Feb 17, 2009 | TruTech TT1620 DVD Recorder
Sony CD recorder
Make sure you are using consumer audio CDR's.Everything else should be straightforward but you should be able to google for the manual.
Nov 04, 2007 | Sony RCD-W10 2-Disc CD Recorder
480 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
