Question about Dryers
Dryer runs cold
Runs but no hot air
  • 3,463 Answers
The most obvious thing here is that the heater element and or stat(s) are not working.
You need to access the heater and stat(s) and test with a meter for continuity.
Plz rate this solution.
Thanks.
Posted on Dec 18, 2008
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
No heat, only cold air
if it is still pluged in and running and you only get cold air check your vent hose it may be blocked by lint or you can put the vent off the back and see if you get hot air then if so the vent is cloged with lint if it is still not blowing hot air then you may have a thermostat open this takes a little more checking you have to take the back off the dryer to check the stats try the vent first white
Jan 07, 2011 | Dryers
Gas dryer no longer gets hot
check the spark ignitor out for that lights up the burner to heat
Mar 11, 2010 | Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
There is only cold air in my kenmore elect dryer
The motor runs on 120VAC. The heating element requires 208/240VAC. Cycle the dryer circuit breaker. Other than a simple issue like that, the problem could be a bad heating element, thermostat, high limit control, thermal fuse, motor centrifugal switch, timer or electronic control. It can also be a wiring issue.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
Marvin
Marvin
