Question about Electrical Supplies
Gas Generator SPark Problem
I have a small gas generator that recently stopped working. I pulled the plug and discovered that there was no spark unless the plug was resting on the metal frame of the generator. Is there a grounding problem? I do not see any wires no connected. Please help.
  • jeff16 Dec 16, 2008
    The generator is a Buffalo Tools brand model gen154. Thanks for any help.
  • 211 Answers
Hi jeff best regards savumihai7
Inside of the rubber boot,at the plug wire terminal there is a spring making connection with the ignition coil(under the flyweel).Check the connection first.Try if there is a spark.If there is not,. remove the flyweel.You will see the coil and ignition wires.Check them by mearurement.Remove the spring and the cover and under it there are breaker points(they has not to be burned).The excentric on the crankshaft open the breaker points(gap) to have spark.Also clean the armature and the magnets from flyweel.Let me know.
Posted on Dec 16, 2008
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Allpower American. 10000w generator won't start? Changed spark plug, gas is flowing. What else can we try?
Make sure it has plenty of oil. Some engines have a low oil shut off. Pull the spark plug wire off and stick a screw driver down inside the spark plug boot and hold the screw driver about a 1/4 inch away from the top of the spark plug and turn the engine over to see if you have a good bluish spark. If you don't then you have a bad coil or rust build up on the flywheel. If you have spark make sure your gas tank is full with new gas. Make sure the air filter is clean. If that doesn't work try taking the bowl off of the bottom of the carburetor and verify gas flows through the float valve. If that doesn't work then you will probably have to remove the carburetor and clean it out.
Feb 15, 2014 | All-Power America All Power 10000w Apg3090...
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Haven't ran my generator since jan. 07'. Tried to start it and no go???
Can be several things. More than likely stale gas. Take the gas line off of the carb. or the tank. Let all of the gas pour out. Remove the spark plug. Pull the rope over and over until it stops blowing gas out of the plug hole. Replace the hose and fill up with new gas. Is the spark plug wet from gas? You can dry it out with a tourch or a blow dryer. Then plug it back to the wire and let it sit on the head of the motor, so it is getting ground. Pull the rope and see if it sparks. If it does the put plug back in and start it up?????
May 21, 2010 | Garden
I have a Gen Power 10hp OHV Briggs & Stratton which is very hard to start. I have changed the spark plug, taken the air filter off but will not start.
I recently had trouble with my own generator. My situation was that the old gas left in the unit smelled more like lacquer than gas, the generator had not been cranked in over a year, and it simply wouldn't even attempt to fire when pulling the starter cord.
I checked the oil level, and drained and replaced the gas. I applied liberal amounts of carburetor cleaner into carburetor. The generater would briefly fire with cleaner in the carburetor. I also removed the spark plug, grounded it against the chasis, and observed good spark when I pulled the cord. This left me to believe gas simply was not getting into carburetor.
I removed the bowl and saw it was full of gas. With a container ready to catch any gas, I opened the valve near the tank and observed liberal amounts of fuel spilling from where bowl mounts to carburetor. So, good gas flow to bowl confirmed.
Using carburetor cleaner and compressed air, I blew out and attempted to clean every orifice I could see. I also checked the float assembly and saw the needle valve that allows/blocks fuel into bowl was operating freely. Reassembled everything, and still wouldn't start.
Took the bowl back out and gave the float assembly further inspection. On my unit, there is a large hole in the center of the assembly where the "perforated brass straw" should be sucking up gas. In the bottom of that hole I discovered a brass plug. I didn't spot this plug before because is was totally encrusted in trash. I was able to remove the plug. This thing is about 4mm long and wide. In the center of this plug I discovered a completely clogged hole. I had to actually scrape it clean with a metal pick, being careful not to damage the metal. I then followed up with lots of carb cleaner and compressed air to make the plug and the tiny hole completely clean. I replaced the plug, replaced the bowl, and the generator fired right up.
I wanted to share my story with you because of the frustration I went through taking my carburetor off at least 8 times before finally discovering this tiny brass plug that no one on any of the forums has ever mentioned.
Apr 30, 2010 | Briggs & Stratton Briggs Stratton 6200...
Hi! there anybody help my power generator won't powering on i even replace the spark plug but to no avail i mean no luck I've try so many times to pull the string for starting up but no luck and even reset...
Take the spark plug out, connect it back to the wire, and rest it so it is touching metal, Pull the cord and see if you see a spark. If you see a spark that means you are not getting gas. Put a few drops in the hole and replace the spark plug. Pull the cord with the choke off a couple of times and it should fire up briefly. If this is the case you will have to clean out the bowl and gas supply lines.
Mar 14, 2010 | Electrical Supplies
It started but when i pluged in ti it it quit. has not started since. checked plug and it was loaded with gas. install new plug and tried. check spark and it appears eratic. pulled air filter off and it is...
sounds like the float is stuck, how long has it ben setting around? try some carburetor cleaner. spray the carburetor down. empty the fuel tank put fresh fuel with fuel treatment. you may have to remove the spark plug, pull starter string a couple of times to clear out cylinder make sure spark plug is dry put back in and try to start the generator.
Dec 10, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Briggs engine/ genreator
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Nov 04, 2008 | Coleman Propane Forced Air Heater...
Electrical Supplies Logo
179 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
