My kingston usb is not working when i put it in the port provided the cpu or laptop doesn't read it.
  • 679 Answers
Try it in another machine, it may be dead, If not, did it work on this machine prior to the problem, and is your machine recognising it when u plug it in
Posted on Dec 15, 2008
Check to see if the drive works in another USB port or in another computer. This should tell you if the problem is with the drive or the computer or port you are using.
What kind of computer are you using?
Does it give any warnings when you plug the drive in?
Dec 11, 2013 | Kingston 8gb usb 2.0 datatraveler g3...
I have my kingston data traveler 101 16 GB. I cannot store videos and music all folders i created are empty please give me a solution to my problem
Ok try to plug it to the USB port at the back of your CPU usually USB port at the back of the CPU supply sufficient power to the device that was plugged in that port so it functions properly cause a USB device plugged to a USB port w/ low or insufficient power supply in that device may cause the device not to work properly that's the reason why your flash drive wasn't recognize by your system. Also that is the reason why you can't view any file in your device.
Jul 08, 2011 | Computers & Internet
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
I have a kingston 2 g flash drive. I put a large number of files from my Dell computer with Vista and the flash works fine on ANOTHER of my computers, a Toshiba Laptop. I put some files on my kingston...
this could be due to the format. i would try different formats on your usb. vista normally reads both but your format may be fat32 which is hit n miss. you can try UDF or FAT. I would format on a vista machine. insert, right click on the drive and select format. you may have to do both with a single file to test reads on both boxes. good luck.
Jun 13, 2011 | Kingston 2GB Secure Digital Memory Card
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston data traveller 2gb flash drive is not detected to my laptop even it was inserted in the usb hub. what will i do?
MAybe ur flash drive is disconnected improperly. when u plug ur flsh drive to usb port, did u hear a beep?
Aug 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingston USB 2GB can't work in my desktop pc .
There are two most common causes of Pen Drive not working
1) The usb port You are connecting it has not enough power output to operate the pendrive (many older computers and laptops have this issue) solution buy an powered USB HUB one with a power adapter You put in a wall socket and then connect Your Pen Drive thruu this hub
2) Operating system lacks drivers for Your particular Pen (windows up to Millenium lack proper usb support and newer I mean XP Vista? (Not sure bout this last one) need administrative privileges to recognise some Pen Drive for the first time or even a driver diskette (some very rare cases).
Jul 23, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Here's my problem, i have a kingston 4GB usb..
I have come across an issue where my USB discs were completely erased "by no reason". I would use it with one client just fine, but when I went to the next, nothing came up. I had to format the drive again and it worked once more. This has happened to me about three times in four years. But it does happen. On your disc, can it be read on some other PC? If it can, then the issue is with the port on your laptop, try a different port. If it can't the it may be the USB drive that went the way of the concorde... out of service after years of functionality. ;-) Have a blessed day, report what happens. -Carlos:
Jun 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Am I supposed to just put the memory stick in the usb port in the front of my cpu? How long does it take before it's done. This is the first time I've ever purchased this.
Most of these portable memory sticks are all plug and play. This simply means they are ready to be used whenever and wherever. Just plug in the drive to your USB port and drag files into the listed hard drive. Just remember, do not pull this stick out of the USB port without pressing "safely remove hardware" on your start bar. Failure to do this can result in frying your flash memory. Best of luck!
Jan 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
MFC application in kingston data traveller encountered problem and needs to be closed
how did you try to format ?, try to unistall the driver when complete put the drive back in usb port. if that doesnt work keep the drive in port and open my computer right click on your thumb drive and go to properties click on tools and try error checking. this is probably where you try to format. once test is done pull drive out and reboot then put drive back in
Feb 27, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
