Question about Proscan PS27125 27" TV
Unable to turn on
When attempting to power up the set ( with the remote or the front control panel ), the TV will makes 4 clicking sounds like it is trying to turn on but with no success.
Short circuit in High Voltage deflection circuit, usually the Horizontal output Transistor. What the 4 clicks are the power supply trying to turn on but it is sensing a short circuit..
Posted on Apr 15, 2007
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I am unable to click on features on the Tv. I changed the batteries and nothing happens as per a connection. # rm-yd016
IR REMOTE programming error Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 27, 2011 | Sony The Miracle Remote for TV Remote...
No picture
Instructions
  1. 1 Make sure the power cord is properly plugged into a wall outlet if your TV is not powering on.
  2. 2 Make sure the video and audio cables connecting your TV to external devices are secure if you are experiencing a fuzzy picture or no picture.
  3. 3 Reset the parental password if you forgot the password and are unable to view certain programs. To do this, click "Menu" on your remote control and use the arrow keys to select "Parental Controls." Enter the master password, which is "4357" to reset the password.
  4. 4 Turn off the caption vision option if you are seeing a large black box on your screen. To do this, click the "Menu" button and select "Setup." Select "Caption vision" and press the "Plus" button on your controller to set the option to "Off."
  5. 5 Check the "TV/Video" setting if you're not getting a picture on your screen. You may have inadvertently selected a video input that isn't active. Press the "TV/Video" button on your remote to cycle through video inputs.
  6. 6 Alter the brightness settings if you are experiencing a poor picture or no picture. To do this, press "Menu" and select "Video." Increase the brightness settings to see if the picture begins to appear.
  7. 7 Make sure the volume is not muted if you are experiencing a clear picture but no sound. Press the "Mute" button on the remote control to turn mute on and off.
  8. 8 Power cycle your Sony Wega if it's frozen or not responding to your remote control. Unplug the power cord and wait a few seconds. Plug the power cord back in.
Dec 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Locked tv set model f19421
These are the instructions on locking and unlocking the control panel for your TV: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 12, 2010 | RCA F19421 19" TV
When turning on the t.v. makes a clicking sound (Normal sound) but the t.v. doesn't turn on, no picture?I am wondering if the t.v. has a reset button or something?
Does any indicator light in front of the TV when you turn it on?
if the answer is yes, try turning on the TV by using the remote control. press any of the programme numbers 1-9 while pointing the remote at the TV. It is advisable that you install new batteries in the remote before attempting this.
If the answer is no then you should do the following:
- check the wall socket. try plugging another device into this socket to see if there is power present
if all the above fail thentake the TV to the repairman.
Oct 02, 2009 | Televison & Video
Big Blur when i turn the tv on
Hi!
First of all please check the following things:
Press the TV button. Make sure the TV is plugged in. Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else. Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions. The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Front Panel Block in the Parental Control menu and press OK to uncheck the box. The TV might be performing a periodic diagnostic check. Wait for a few minutes for the TV to turn on.
If still the problem persists then check the following:
Maybe the cable/air function is set to the wrong position. The channel might be blank — change channels. If you’re watching your VCR and it’s connected with coaxial cable to the CABLE/ANTENNA jack, tune the TV to channel 3 or 4 (whichever channel is selected on the 3/4 switch on the back of your VCR). Also check to make sure the TV/VCR button on the VCR is in the correct mode (press the TV/VCR button on your VCR). Check antenna connections. Make sure all of the cables are firmly connected to the jacks. Try adjusting sharpness function to improve weak signals. Closed-captioning might be on. Check Closed Caption in the Setup menu.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Cannot control volume
Dear Mbruce 1,
With set on press and hold the "Power and Action Buttons" on set, for about five seconds, set will turn off and then back on.
Please let us know!
Toprol
Oct 15, 2007 | Panasonic TH-50PX75U Plasma HDTV
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Televison & Video Logo
65 people viewed this question
Top Proscan Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
