Question about Motorola Mobility V300
Can't hear callers unless speakerphone is turned on
Can't hear callers and sometimes they cant hear me unless speakerphone is on. how to resolve? Moto v300
Hi I have just had the same problem and I found that some how the auto handsfree had been set to on. To resolve this I went to >SETTINGS >CAR SETTINGS>AUTO HANDSFREE and turned the handsfree OFF. The phone now works ok and I can hear all my calls without pressing the speaker phone. I hope this helps you Regards sootyman
Posted on Apr 22, 2007
I have 3 motorola v300 that my friends gave me because the same problem. after looking for a solution in the internet I found the solution and I am very excited and happy to share with you guys. try it at your on risk
motorola v300 has a manufacturing problem. to make sound the little speaker has to move freely back and forward. but is constricted by a metal plate the is in its back . to resolve the problem. follow this steps.
1 - turn turn off the phone .
2- flip the phone open.
2- around the screen , you gonna see four little dot lids that cover little screws.
3- take off the little lids and then the four little screws , don't loose them.
4- take off the FACE Plate.
5- using a needle nose plier pry outward the metal plate 1mm will do.
make sure the the steel frame is not touching the earpiece.
6- turn on the phone.
7-call your voice mail to tested. and enjoy it.
if you think this to much a challenge for you get help for somebody that can doit for you; it is pretty easy.
the screws are a torx type. you can borrow the screwdriver from any cellular store that sells personalized FACE PLATES
drop me a thanx note to esky111@hotmail.com with the subjet "motorola v300" I want to count the number of people I helpped it.
PS pardon my english.
Posted on Jan 10, 2008
5- using a needle nose plier pry outward the metal plate 1mm or 2 mm will do.
if you think this to much a challenge for you get help for somebody to do it for you. it is pretty easy.
drop me a thanx note to esky111@hotmail.com with the subjet "motorola v300" I want to count the number of people I helpped.
Thank you for your suggestions
Posted on Apr 23, 2007
  • 74 Answers
Dear. this prob from speaker may the speaker point get carbon or moist. sold them if not ok check speak with meter if not ok then replace it.
Posted on Mar 26, 2007
SOURCE:
Palm pixi cant hear caller, caller cant hear me. Sometimes switches to speakerphone automatically and works for a short time
remove the battery for about ten minutes. put it back in and turn on the phone that should sort it out
Jan 09, 2011 | Palm Pixi Cell Phone
Callers can only hear me on speakerphone
first try to formate the set ...and problem is still there then its hardware problem ....you hv to change your phone's Mic
Jul 17, 2009 | RIM BlackBerry Pearl 8100
No sound unless in speakerphone mode. It rings & dials just fine. However, when I flip it open, I can't hear the caller. I can communicate normally if I switch into speakerphone mode. This is a recent...
Seriously, sometimes if you have the other person yell, it will just magically "pop" back in. THis only lasts a few minutes though. Unless you can deal with speaker phone, I suggest a new phone.
Jul 02, 2009 | LG CU400 Cellular Phone
Can only use speakerphone to hear caller's voice on my iPhone
It's usually caused by a defective or dislodged electronic module that sits behind the ear speaker, this should be covered under warranty unless there are visible marks of the drop. If you're not covered, you can try a iphone repair guide websites, there are also places that sell iphone parts.
Apr 08, 2009 | Apple iPhone 3G Black Smartphone
When I get calls, I cant hear anything out of my phone unless it is on speakerphone, but the person on the other end can hear me perfectly. This has happened in three different Venus' that I have had...
did you change your earpiece setting on the my settings menu, it's under Sound settings. you can change it to low to high. And when you answer the phone, you traditionally answer it the portrait way?
Mar 06, 2009 | Verizon Communications Samsung Alias Cell...
Can't hear caller
The earpiece speaker has gone bad. Unless you have access to a replacement speaker and can solder you will have to take the phone to you nearest Motorola service center.
Sep 05, 2007 | Motorola Mobility RAZR V3
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
CHANGES PROFILE on its own; callers can't hear me, and I can't hear them
u just have to do take back up first then by going to settings click on master reset it will resolve ur issue good luck
Sep 26, 2006 | Sony Ericsson S710a
Motorola Mobility V300 Logo
228 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
