Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Vertical black line down centre of screen
Line is always in the same place on the screen and is more prominent on some channels than others (particularly sky sports).It is not a thick line,in fact on some stations it is quite faint,but it is always there in the same position and is very annoying
  • 6 more comments
  • kaht22 Dec 16, 2008
    i have the same problem but also have lines on each side too.
  • sjroe Dec 26, 2008
    i have same problem faint black line straight down middle offscreen very annoying.
  • pluc Jan 10, 2009
    i have the same problem, have had the 47" regza for a year and a half and now there is a perfectly straight thin vertical line down the right hand portion of the screen.
  • gag1966 Jan 14, 2009
    I have exactly the same problem on the 42" version. Very thin faint line down the centre of the screen that has just appeared.
  • Anonymous Jan 15, 2009
    We have a Toshiba Regza 47" lcd hdtv for a year....several months ago a vertical black line appeared on the right side approx 6 inches from the frame edge. Is this a problem with this particular model with Toshiba? Any feedback would be appreciated...Thank you...E. Connell, Lakeland, Fla wecon163@tampabay.rr.com
  • Anonymous Feb 01, 2009
    I`ve got the same tv and the same problem, dont think its to do with channels, but how dark the picture is. Can only see the vertical line down the centre of the tv when the picture is light colour eg sky, light blue sea etc
  • jakeanderson Feb 23, 2009
    I also have a vertical line down the middle of my Toshiba Regza 42" LCD screen. I called Toshiba and they said this was the first one they had heard of. They said it was likely the source of the signal, however, it appears on the screen from the satellite box with a monster cable, a HD DVD player with a highend HDMI cable, as well as multliple gaming consoles. Regardless to say that I'm very dissapointed and will not buy a toshiba again.
  • Anonymous Mar 14, 2009
    We had the same problem on a Regza 3030D 42" and reported it to Toshiba UK Customer Services. They arranged for a new TV to be sent out and replaced ours at no additional cost. Their service was first class.
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Posted on Mar 13, 2009
I have the same problem a thin black vertical line on the right and left sides of the screen.
Posted on Jan 23, 2009
Thin black vertical line near the centre of the screen what is the cause?
ok go to menue if still you have this problem your panel is not good
but if this problem disappera then this the problem of your T-CON BOARD for falt cables that attached to T-CON board
Oct 14, 2014 | Samsung PS50Q97HDX 50 in. Plasma TV
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
I have a panasonic 48 inch plasma TV which has developed a fault. There is a yellow line down the centre of the screen on all channels. Is the TV knackered?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help in solving the problem.....
Jun 15, 2011 | Televison & Video
ONE VERTICAL LINE FOUND ON THE SCREEN AT THE TIME OF PHOTO SHOOT AND AT THE DARK PLACE THE VERTICAL LINE OBSERVED MORE PROMINENT THAN LIGHTING PLACE.
restart your camera by taking out the battery or clear the lens or the screen by dry cloth...restarting the camera will definitely solve your problem
Mar 11, 2011 | Canon PowerShot A480 Digital Camera
Only top half of screen has picture there is a white line through the centre and bottom half black
If this is a conventional TV with the original style Cathode Ray tube, this fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around £70 ($120), possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it will certainly damage the tube if you leave it running with that white line through the centre!!!
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the white line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Nov 17, 2009 | Televison & Video
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Black line
is it a vertical or horizontal line?
Feb 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
3,665 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
