Question about Coleman Powermate Powermate 5000W Generator
Gas used How long will 5 gal of gas last?
    Problem Solver:
  • 4 Answers
11 Hours with a 50% load.
Posted on Dec 16, 2008
Unscramble letters to create a word. letters: scsgtlaae
Alga Sects
Gala Sects
Galas Sect
Cage Slats
Cage Lasts
Cage Salts
Glaces Sat
Cages Last
Cages Salt
Cages Slat
Lace Stags
Scale Stag
Scale Tags
Laces Stag
Laces Tags
Scales Tag
Eclats Sag
Eclats Gas
Cleats Sag
Cleats Gas
Castle Sag
Castle Gas
Eclat Sags
Cleat Sags
Castes Gal
Castes Lag
Caste Slag
Caste Gals
Caste Lags
Lac Sagest
Lac Stages
Lacs Stage
Lacs Gates
Class Gate
Talcs Sage
Talcs Ages
Talc Gases
Talc Sages
Casts Gale
Scats Gale
Acts Gales
Scat Gales
Cast Gales
Cats Gales
A Lacs Gets
A Class Get
A Sacs Gelt
A Casts Leg
A Casts Gel
A Scats Leg
A Scats Gel
A Acts Legs
A Acts Gels
A Scat Legs
A Scat Gels
A Cast Legs
A Cast Gels
A Cats Legs
A Cats Gels
A Gal Sects
A Lag Sects
A Slag Sect
A Gals Sect
A Lags Sect
Lac Sag Set
Lac Gas Set
Lac As Gets
Lacs As Get
Sac Gal Set
Sac Lag Set
Sac Sag Let
Sac Gas Let
Sac Stag El
Sac Tags El
Sac La Gets
Sac Las Get
Sac As Gelt
Sac Sat Leg
Sac Sat Gel
Sac At Legs
Sac At Gels
Sacs Tag El
Sacs La Get
Sacs At Leg
Sacs At Gel
Acts Sag El
Acts Gas El
Acts As Leg
Acts As Gel
Scat Sag El
Scat Gas El
Scat As Leg
Scat As Gel
Cast Sag El
Cast Gas El
Cast As Leg
Cast As Gel
Cats Sag El
Cats Gas El
Cats As Leg
Cats As Gel
Cat Sags El
Cat As Legs
Cat As Gels
Act Sags El
Act As Legs
Act As Gels
Gal As Sect
Gal Sat Sec
Gal At Secs
Lag As Sect
Lag Sat Sec
Lag At Secs
Slag At Sec
Gals At Sec
Lags At Sec
Sag La Sect
Gas La Sect
Stag La Sec
Tags La Sec
Tag La Secs
Tag Las Sec
Oct 27, 2016 | Computers & Internet
I have 1/2 can of 8 oz oil per 1 gal gas. I need to change it to 2.6 oz oil to 1 gal for a weedeater. How much gas should I add to what I have to get the proper mix of 2.6 oz to 1 gal gas?
you buy a really small measuring cup . or guess at it .1/2 can will be 4 oz half is 2 so it is someplace between the 2 of them .
Oct 16, 2016 | Garden
My craftsman 200mph/430CFM 25cc leaf blower will start and last for about 5 mins. on half choke and then die out and not start. It cant be put on run or it will die right away.eplaced spark plug. Still...
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 12, 2012 | Craftsman Garden
1988 dodge ram 318 engine drives fine for 10 to 15 miles, after it heats up it runns real ruff and smells like two much gas in exhaust have to press fuel a little to keep it running with foot on brake at...
Code 12--Battery Disconnect---Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections.
Code 37--Torque converter clutch solenoid CKT or Trans temp sensor too high or low---Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input.
Code 55--End of message code. A DTC 55 is used to end all DTC messages.
When is the last time you had a tune-up? I would start by replacing the cap, rotor, plugs and wires. Also, check all hoses for vacuum leaks.
I hope this helps.
Jul 06, 2011 | 1988 Dodge Ram 50
We are going to lose power at 12 am tonight and my husband has sizures and we need generator so we bought one but cannot find manual how long will it run? we bought at menards
I really depends on the size of the generator. 1 gallon of gas should last close to an hour, the tank should hold about 3-4 gallons so I would say atleast 3-4 hours but keep a check on the level as you never know when leaks occur, or how much gas it sucks up. Good Luck
Oct 09, 2010 | McCulloch Garden
Car has not been driven much. Last i drove it it
put some octane booster or fuel conditioner in it and put about 5 gal of premium gas in it. From sitting it may have moisture build up in it.
Feb 09, 2010 | 2001 Buick LeSabre
Fuel gage computer problems
fuel gauge is controlled by a sending unit in the gas tank.
Nov 14, 2008 | 1990 Cadillac SeVille
Coleman Powermate Powermate 5000W Generator Logo
44 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
