Question about Tecnik TKL9290 Front Load Washer / Dryer
Belt Replacement I want to replace the belt, but can't work out how to loosen the mounting for the motor can anyone help?
  • Steve Archer Mar 20, 2007
    Sorry I'm still not sure so I've attached a photo.
  • Anonymous Mar 03, 2008
    put the belt on the motor then push it round the drum until its all on
  • 944 Answers
Sorry couldn't find a picture online, you could ask these guys; http://www.tecnik.net/aftersales.htm Usually these motors are mounted with a screw device somewhere on the side away from the hinge which can tension or slacken the belt. sometimes the whole motor is mounted on a sled, which can be moved to slacken the belt, probably by undoing 1 or two screws in the sled that slide in a track. if you have no luck with that then see if there is a small grub screw in the side of the pulley on the motor, if so you should be able to slide the pulley off to change a belt. Hope this helps :)
Posted on Mar 20, 2007
Does anybody have a diagram and/or instructions for changing the serpentine belt on a 1998 celica?
REMOVAL & INSTALLATION
See Figures 12, 13, 14, 15 and 16
If a belt must be replaced, the driven unit must be loosened and moved to its extreme loosest position, generally by moving it toward the center of the motor. After removing the old belt, check the pulleys for dirt or built-up material which could affect belt contact. Carefully install the new belt, remembering that it is new and unused - it may appear to be just a little too small to fit over the pulley flanges. Fit the belt over the largest pulley (usually the crankshaft pulley at the bottom center of the motor) first, then work on the smaller one(s). Gentle pressure in the direction of rotation is helpful. Some belts run around a third or idler pulley, which acts as an additional pivot in the belt's path. It may be possible to loosen the idler pulley as well as the main component, making your job much easier. Depending on which belt(s) you are changing, it may be necessary to loosen or remove other interfering belts to get at the one(s) you want.
Fig. Fig. 12: On some components a front pulley bolt must be loosened ... .
Fig. Fig. 13: ... then the upper bolt so you can ...
Fig. Fig. 14: ... lift up and remove the drive belt
Fig. Fig. 15: Once the front belt is removed you can access the other belts in need of replacement
When buying replacement belts, remember that the fit is critical according to the length of the belt, the width of the belt, the depth of the belt and the angle or profile of the V shape (always match up old belt with new belt if possible). The belt shape should exactly match the shape of the pulley; belts that are not an exact match can cause noise, slippage and premature failure.
After the new belt is installed, draw tension on it by moving the driven unit away from the motor and tighten its mounting bolts. This is sometimes a three- or four-handed job; you may find an assistant helpful. Make sure that all the bolts you loosened get retightened and that any other loosened belts also have the correct tension. A new belt can be expected to stretch a bit after installation so be prepared to re-adjust your new belt.
After installing a new belt, run the engine for about 5 minutes and then recheck the belt tension.
Fig. Fig. 16: Make sure the belt is aligned on the pulley correctly
Oct 26, 2012 | 1998 Toyota Celica
How to change the power steering belt on a 2004 mitsubishi galant
The power steering belt is on the front of the motor and is driven by the crankshaft. Below the steering pump is an adjuster bolt. It moves a pulley underneath the pump. To adjust the belt tension located the nut that tightens the adjuster pulley the the pump bracket . It is on the right side of the bracket , the pulley is on the left facing the back of the car. Loosen the pulley mount nut . You can now turn the adjuster bolt to move the pulley to tighten and loosen the belt for replacement. I recommend replacing the alternator belt at the same time. To do this , Unhook the negative battery cable, loosen the bolt holding block to the slide arm, reach under the alternator and loosen the lower mount bolt, not you can adjust the position of the alternator using the adjuster bolt.
Oct 02, 2010 | 2004 Mitsubishi Galant
How do i replace the motor drive belt
Open motor shroud to expose motor area then go to the other end of your treadmill and loosen the running belt this done mostly with a allen wrench count how many turns counter-clockwise it take to fully loosen the belt. then loosen the motor, depending if its mount up against the or the bottom of frame they will have bolts to loosen if its on floor of the frame mark the bracket so when you put back the new drive belt you should in the ball park to adjust the tension. depending on the model some front rollers are fixed and you only need to loosen the two two bolts lift the roller up replace the belt work backwards on the steps you performed.
Feb 07, 2010 | Exercise & Fitness
Difficult belt replacement on 1997 Olds 88
the motor mount needs to be removed to replace the belt. so, if you've never removed a motor mount, I would let them handle this.
Dec 30, 2009 | 1997 Oldsmobile 88
2001 kia sportage need to get info on how to change the timing belt, 2.0 motor forward facing motor, needs power steering replaced, timing belt.
Below are the steps..
Disconnect the negative battery cable. Remove the two fresh air duct mounting bolts on the radiator. Loosen the fresh air duct clamp at the intake housing. Remove the hose at the resonance chamber. Remove the frech air duct. 2bea4d1.jpg Remove the five cooling fan shroud bolts. ab00c68.jpg Remove the four thermo-modulated fan nuts. Remove the four thermo-modulated fan cooling fan shroud at the same time. 289c5ca.jpg Loosen the two generator mounting bolts(A and B). 2a96c03.jpg Loosen the generator drive belt from the generator by loosening the adjusting bolt(C). Remove the generator drive belt. Remove the fan pulley. Remove the four splash guard mounting bolts and splash guard. f912ce0.jpg Loosen the A/C idler puller nut(A). c0690b5.jpg Remove the A/C drive belt by loosening the adjusting bolt. Loosen the power steering pump lock bolt and mounting bolt. 843d3b3.jpg Remove the power steering belt. Remove five bolts and the upper timing belt cover. Refer to Timing Belt. Remove two bolts and the lower timing cover. Refer to Timing Belt. Loosen the tensioner lock bolt and pivot the tensionder pulley outward to remove the tension from the timing belt, then re-tighten the tensioner lock bolt. 7ca4ca0.jpg NOTE: Tightening Torque : 27-38ft·lbs(37-52N·m) Mark the timing belt rotation for proper reinstallation if it reused. Remove the timing belt. Be careful not to allow oil grease on the belt. c5d4c02.jpg Regards, Jeep Brainy
Sep 16, 2009 | 2001 Kia Sportage
Change alternator belt on 1996 buick riviera
The 96 Riviera has a motor mount that interferes with the removal and replacement of the serpentine belt. The motor mount must be loosened and the engine need to be lifted slightly to accomplish the replacement. Not good engineering on this model year.
Aug 26, 2009 | 1996 Buick Riviera
I need to replace the belt
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Motor mount replacement at 93000
Your best bet would be to pick up a Chilton manual from autozone. It will give you step by step instructions on how to do all kinds of things with your vehicle, including the motor mounts.
May 24, 2009 | 2003 Kia Optima
Replacement of the serpentine belt on 1997 buick lesaber how
Yes, I have a 97 buick and the motor mount does have to be removed. See information below that I retireved from Autozone.com:
See Figures 7 through 13
  1. Disconnect the negative battery cable.
0900c152800b19a8.jpgFig. 7: Many vehicles have an accessory drive belt routing label affixed to the radiator shroud
  1. Remove the belt guard or coolant recovery reservoir as required.
  2. For 1996-99 supercharged engines, perform the following:
    1. Raise and safely support the vehicle.
    2. Remove the right-hand splash shield.
    3. Remove the connector from the crank sensor.
  3. For 1996-99 vehicles, remove the engine mounting bracket lower nut, stud and spacer. Carefully lower the vehicle.
Jan 25, 2009 | 1997 Buick LeSabre
Fan Belt replacement
Sort of, look at the belt closely before you remove it to make sure the belt is not looped through the motor mount. On some makes there is a motor mount that is attached to the sidewall of the vehicle and this mount must be removed to remove and reinstall the belt, otherwise, yes it is that simple. Make sure you know how the belt goes back on. There should be a diagram under the hood for the belt routing. Or you can grab a sheet of paper and draw it yourself. If you do attempt to change it and the motor mount must be removed, you have to support the engine weight with a jack before removing the mount. Be careful and please let me know if this was helpful.
Jan 15, 2009 | 1995 Buick LeSabre
Washing Machines Logo
83 people viewed this question
Top Tecnik Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Alan Chouinard
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
