Question about Apple MacBook Pro PC Notebook
Sync problem in cubase sx
When i play the two tracks at the same time there is synchoronisation problem .there is a delay of fractions of a seconds
  • wakoy_2006 Dec 20, 2008
    while im on recording process synchro seems ok but then when i made playback the tracks are not on the same timing its really frustrating
  • 679 Answers
Try resetting it if there is a reset on the card. If not there has to be a solution associated with the software. Did it happen while you were using it? Try the default settings
Posted on Dec 15, 2008
Latency during recording - makes playing in time impossible
I can totally relate, Tom. Good old multitrack recorders!
This may sound stupid, but you don't have like a slap back delay turned on by mistake, do you? Other than that, I'm afraid I'm not much help.
Mar 11, 2014 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I need to sync my snowball into cubase sx... its only recording on the left input not the right input of the audio wave. please help get back to work.
This is strictly a software setup problem. I use Sonar, but Cubase has to have the same features. Look for a PAN control and also where you MIGHT be able to select that both channels of the stereo are mapped to the single input. A work-around might be to bounce the input to a second track and then do a channel swap on one of the stereo channels, then combine them. I think Cubase uses the word "flip".
Search your documents for keywords: flip, bounce, swap, pan, and assign input. You can also copy and paste the recorded channel to a second stereo blank channel before flipping it and combining.
Mar 14, 2013 | Blue Microphones Snowball Professional...
Good morning I have Cubase SX version 1.01. lately when I record vocals to a track. Im noticing that the Vocals are not in sync with the music. one is playing slower than the other track.. the slower is...
I don't 100% understand why Cubase does this. I'm assuming it's a memory (RAM) problem. If you record loud and clear anough you can just drag the tracks to where they're meant to be afterwards because you can see where they go relative to the other tracks
Aug 20, 2010 | Steinberg Cubase SX3
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Delay
if i understand it right, you recorded for example 2 tracks. recorded A then recorded B then you synced them together? if so, my bet would be adjusting the volume for each giving them balance. your master volume is your guide on this. hope this works.
Feb 06, 2009 | Steinberg Cubase SX3
Can't change the tempo on cubase sx
on the play panel click track
Oct 28, 2008 | Steinberg Cubase SX3
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Delayed vocal
If you're recording to an audio program on your computer (e.g., Cubase), there typically is a slight delay in the tracks you record with the first one (such as a slight delay in the vocal when layering over the guitar track). ou can change the delay in the "Preferences" for the audio card in your computer or you can remove the delay manually.. I do the latter. I record using the Audacity 1.3.3. program on a Mac G4. I find that get a 0.3 second delay in tracks layered onto the first track. So, after I record a track, I cut the first 0.3 seconds froom the beginning of the track (I give myself at least 10 seconds of "dead air" at the start. and keep playing the tracks until they're synchronized. Takes a good ear, but really is the best way to synchronize the tracks.
Nov 10, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
Problems recording with Tascam us-122
you dont say what program you are using to record on. If it's cubase sx it's the fault of the program not the soundcard. Contact cubase and they will give you the fix
Jun 02, 2007 | Tascam US-122 USB Audio/MIDI Interface...
Apple MacBook Pro PC Notebook Logo
65 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
