Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Tv will not power up
My mitsubishi projection tv. will not power up although it indicates no fault at self diagnostic test........
    Problem Solver:
  • 6 Answers
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
My mitsubishi rear projection tv will not stay on
The model number indicated has a self test: when power light goes off at turn on:
on front of set press and hold both menu and input buttons at same time for at least 10 seconds and let go of both.
Power light will blink a two digit error code like 1 blink, 2 blinks a pause and repeat it several times.
What if any error code do you get?
This will narrow the problem to a specific area of the set.
sj
Aug 29, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I am geting a blink code of 1 blink followed by 2 blinks
Replace both of your STK ICs will have number on them call mats 1-800-628-1118 for parts they are big black ICs STK394-250 go by # on yours
Sep 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Tv will not power up. green light comes on for
I have the same problem, did you ever get yours fixed if so what was the problem
Aug 17, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Tv won't start
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
May 05, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Timer light is flashing tv want come on
connected.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Jan 22, 2009 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishi vs45607 dead
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-45603 45" Rear Projection...
No Picture At All on my DLP Mitsubishi
First do a self test to get error codes. To do this look on threads here or go to ctechnicians.com
Dec 31, 2007 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi wd-62327 red light
1. Self-diagnosis error 4-4, check for open F9A06 part # 283P128050 on the Power PCB. 2. Self-diagnosis error 4-4, check for proper seating of the DVI cable between the FMT PCB and the DMD (Light Engine). It may be necessary to disconnect and reconnect this cable to insure proper connection. 3. Self-diagnosis error 4-4, if F9A06 is good and the connection on the DVI cable between the FMT PCB and DMD are secure, suspect the Light Engine part # 939P977020 4. Self-diagnosis error 4-4, check F9A07 part # 283P128050 on the Power PCB, if open suspect the Light Engine part # 939P977020 5. Self-diagnosis error 4-1, suspect the Power PCB part # 930B929001
Sep 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
