System cannot find harddisk - Computers & Internet
  • longaxe May 11, 2010
    Have you verified:
    -that the ribbon cable is in tight and properly plugged in on both ends?
    -that the power connector is properly plugged in?
    -that the master/slave jumpers are properly set?
    -that the hard drive is good by trying it in another machine?
  • 585 Answers
Ok, let's assume that this is a system that was "cookin' with gas" one day and just wouldn't boot the next, and you saw the message that the hard disk cannot be found. There are not many possibilities, but one is the failure of the drive itself. Meaning a device on the pc card on the drive failed, the drive no longer reports it's presence to the bios, and the drive may no longer even spin. If the drive is spinning, and eminates a brief ratcheting noise at application of power, perhaps the bios has a problem, and is just not seeing the drive. If you feel that may be the case, boot from cold, look for a prompt "press xxxx to enter setup" and select that key to enter the setup of the bios. If you see a prompt in the bios for "load defaults" select it, and then "save and exit". Reboot the system and see if the problem is corrected.
Posted on Dec 15, 2008
  • 679 Answers
Did the machine recognise the drive before, or is this a new build?Is it a SATA drive, and how many other devices are running into the ribbon. Try clearing the cmos, and try again if it worked before.
It's saying operating system not found
before giving the solution, need to know whether the system was working fine in the previous start? and what all the solutions tried from your end?
just give a try with these solution:
1. just enter into the bios and check whether ur harddisk is getting detected.
2. if yes, just check the boot order..and set the first bootable device to your harddisk.
3. try to reconnect your harddisk (best try).
4. if the above solution not works just try to repair the your operating system.
Nov 05, 2012 | Computers & Internet
My computor wont get to windos and declares opareting system not found. faliue. please contect me to idans84@gmail.com
Most times when this type of problem arise it always because the harddisk is damaged but on another hand you should try to format and reload your harddisk with another operating system first thereafter if the harddisk doesnt accept the installation of the Operating system then you can fanalise that the harddisk is dmaged and you need to buy another..
[pls remember to rate me
Jan 01, 2011 | Dell Inspiron Mini 10 Notebook
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Lacie drive can't display in my computer
First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
Thanks.
Happy to help you.
Apr 24, 2010 | Microsoft Windows XP Professional
Error loading operating system
there might be problem with your operating system... reinstall it.......or may be your harddisk is making some problem plug out cables of harddisk and put them again correctly.........
Jan 29, 2010 | ASUS P5PE-VM Motherboard
My Hp Pavillion laptop dv2214tu doesnot boot beyond the HP INVENT logo page. I tried performing the Primary Hard Disk check as stated on the HP Support site but its not happening.I also reseated the RAM...
Unscrew your Laptop HardDrive bay and remove your harddisk first, then try to boot your system wthout the Harddisk inside. If it Boots past the HP Invent Logo Page, then your harddisk is the one that is faulty, if still doesnt, get another good, working RAM, apart from the one in your system, and use it to test your laptop...making sure that the harddisk is still not inside...then if it boots insert your Harddisk back with the new RAM, and restart your system.
If in the first case it boots (i.e wihout the harddisk inside)...then it means your harddrive is faulty, just retrieve your file on it and get a new one.
If in the second case it works (i.e with a new external RAM) then just change your RAM instead.
Jul 09, 2009 | HP Pavilion Notebook
Lose of Master Harddrive
have a check with the BUS cable once try replacing the BUS cable which is connected to the HARDDISK .. there may be some problem in the IDE BUS CABLE...
you can fix that by replacing with the new one ...
this problem is not where related to BIOS ..
because if there is any problem in the IDE BUS CABLE means you will face this problem ..
there is one more case it is not oftenly seen actually ..
ie if there is any problem in harddisk means you will face this problem ..
normally the harddisk will work without any problem for 10+ years ...
in very special cases the harddisk failure occurs which is called as catastrophic failure ie the harddisk makes some hissing noise before when it attempts run , this problem may be due to some manufacture defect or if the harddisk is not being used for a long period of time (may be years) ...
so just have a check with things everything will be alright ..
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Sep 02, 2008 | MSI K8MM3-V Motherboard
File system
file system is another memory space ,where it stores the address of the data i.e,(datas in harddisk) .
ex:(songs in harddisk) if u click the .mp3 icon.. they pointer wil move to the filesystem and searches for the address (harddisk address)... then the pointer jumps to the harddisk address... then song plays
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Disk Boot Failure
you need to select ur harddisk as the first bootable device., that option is in BIOS settings. When switch on the system before loading OS press F2 to get the BIOS settings and select boot option in the menu and select your harddisk as the first bootable device. Restart the system now. If the same error is displayed your harddisk data cable may be failed or your harddisk may be corrupted...
Jul 11, 2008 | Computers & Internet
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
