Hardisk failure - Computers & Internet
  • 585 Answers
You don't give a lot to go on here. If your disk has failed, you will need to replace it. Are you sure the disk has failed? You may want to take a few steps to determine if the disk is really at fault, maybe something has happened to corrupt the boot sector and though the disk is fine, it cannot be read. There are restore utilities available on the internet to fix the boot sector of the corrupt drive. And you may even have such on the restore disk that came with the computer.
Posted on Dec 15, 2008
  • 679 Answers
If you are talking about fixing it, forget that. You really cannot fix a hard drive if it fails. To get the old data off is almost impossible for anyone who isn't a pro. All you can do is to replace the hard drive, and from now on, back up your drive to an outside sourse, like a usb hard drive. Then if it should fail, you at least have your data
Disc boot failure, insert system disc and press enter, I have no disc what to do?
that was mean the hardisk failed to boot, tried to replaced the IDE or sata gate in the hardisk and reboot the system.
Oct 12, 2012 | Evesham Evolution PC Desktop
I have a D865perl MB some times for no reason my computer shuts down. It is a pain to restart, i have to turn it on and off atleast 20 times
That looks a hardisk failure.
Set the BiOS to "max. default operation", save upon exit. If you still got the same problem replace the HARDiSK.
Try to replace the hardisk and install your favorite OS.
Hope that helps!
Dec 02, 2011 | Intel D865PERL Motherboard
Have a compact persiro f700 and am getting a message that states that SMART disk failure and windows will not load and cannot boot computer into safe mode Please Advise on what to do next?????
You could open the bios set up to check the hardisk and memory card, see if it is being read by the board.
Try to set your boot sequence to "default option" and save the changes. reboot again afterwards.
If there is a rebooting, but still can not read the hardisk, it means, that is a hardware breakdown, mainly the hardisk itself. Try to replace the HD( hardisk) if you have any spare ones, just to check the system.
Your local computer shop can assess it and tell you what causes the problem. we are just advising you if you could repair it by yourself and my pointers to what you are going to repair in your laptop.
Hope that helps you out.
Thanks for using FixYa!
Jun 30, 2011 | HP Compaq Presario F500 F700 and G6000...
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
Start
Some missing data or corrupetd data, that is the cause, try to re-install your OS.
Restart problem
Your 2nd hard drive is failing. Until you repair or replace it this message will continue to appear.
Oct 30, 2009 | Toshiba MK2035GSS 200 GB SATA Hard Drive
Hardisk cleaned why?
this may be a hdd physical failure, best to check this would be to connect disk to another computer for a minute and run full HDTACH tests, if it's not damaged, then boot record is damaged, and Partition magic or similar program is needed to delete partition and re-create it
Sep 19, 2009 | Western Digital 250GB MyBook External USB...
IR3570 error code E000602-0003, screen won't come on, won't copy or fax
this error is related to machine hardisk problem/failure,,It needs hardisk replacement with IR 3570 sytem software You need to contact your service provider to fix this problem
Jul 19, 2009 | Canon Office Equipment & Supplies
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
