Question about Kitchen Ranges
Wire a 5 wire cooktop
Need wiring diagram for maytag cook top
  • 78 Answers
If you have a model number for this cook top you can find the schematics here jast enter the model number:
http://www.servicematters.com/corner/corner_main.htm
Posted on Dec 15, 2008
Maytag cook top Model # CSE 9000 ADB. A red, black, blue, yellow, white, and bare copper wire come out of the unit. How do I hook it up???
each colored wire is for a seperate burner, the white wire connects to the white neutral wire the bare wire connects to the ground the red and yellow wires connect to the red wire (L1) and the black and blue wires connect to the black wire (L2). i have the same model and i connected mine this way and it's working fine. mine is also connected in a box that has a seperate fuze for each burner so you can follow the red (L1) wires to the 2 fuzes and connect your red and yellow wires to these fuzes and the follow the black (L2) wire to it's 2 fuzes and connect your black and blue wires to these fuzes. i don't know if this box is necessary or ir you can just connect directly to the wiresin a regular box and rely on the breaker but it was already there from the old cooktop i replaced so i used it. hope this helps you
Jan 07, 2011 | Maytag 30 in. CSE9000 Electric Cooktop
Was using 4 burners and they all stopped working- electric burn smell in kitchen. External house breaker is not tripped
When you used all elements the power supply wire have been
gone to the maximum current absorbed so to the maximum heat. When the cook top
is new it can withstand this heat but due to long time used now you have burned
out wires and probably to junction point. So now the power supply wire is
burned and is open circuit thus not any power to the heater. The wires have
just open circuit and they don't touch each other or the metal body of the cook
top that is why you don't have the circuit breaker fuse to trip off. So now you
need to disassemble the cook top and you will very easily find the burn point
which should be melded and burned black and replace all parts that they have
been burned with new one.
Here is the link where you find the parts layout, the wiring
diagram and also order any parts you might need.
Also just for safety, avoid to use all four heater at the
same time in the future.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170741&diagram_id=28477270#d28477270
Dec 18, 2010 | Maytag MEC5430BDS Electric Cooktop
Power requirement
If you are running new wire to the cook top. You need to run 10x4 wire. The 12x4 wire is not large enough for the 220v. Also the 20 amp breaker is not large enough to run the cook top. You need to use a duel 30 amp breaker.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 09, 2010 | Jenn-Air JEC6288AAB Electric Cooktop
Cooktop keeps blowing fuses. when we hit the
you will have to remove top and find short . it sounds like a burner of melted wiring. .. also ck the swithces for dark connections as the could be the cause. mm
Jun 30, 2010 | Maytag MEC5430 Electric Cooktop
Maytag MGC5430 cook top range IGNITION KEEPS TICKING & SPARKING WHILE GAS IS OFF
This sounds like a burner switch.There is one under every knob there are two wires going into them. i think the part number is 7403P367-60.
Jun 22, 2010 | Maytag MGC5430 Gas Cooktop
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
Maytag gas cook top. One burner will not spark. other three are fine. What need to be checked or replaced? I am pretty handy but know nothing about these cook tops. Your input please.
Took entire cook top apart, dried each of the components then reassembled. I donot recomment this unless you are very handy. Not an easy job but doable. Also
try to dry it out with a hair dryer on low.
Nov 26, 2009 | Maytag MGC5430 Gas Cooktop
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
211 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
