Question about Epson Stylus Photo R200 InkJet Printer
Blank page hi , i am having problems with my printer and i need your help.i recently changed the cartridges and now i can't print anything.I only get blank pages. When i print a test page i only get the symbol at the top left in pink color and that's it , nothing else . When i try to print a nozzle check ,only part of the pink one comes out and not like it has to be. Thanks for your help
  • Epson Master
  • 691 Answers
If you use compatible inks, please make sure you have removed any tape that covers the vents. If the tape is not removed the air can not get in and thus the ink can not get out. If you are using genuine carts you can try the following manual cleaning method. --------- You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag. The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead. With the top of the machine open, you should be able to move the print head carriage by hand. Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink. Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image) Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked. Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something. What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick. Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers. Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times. Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel. Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines. This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem. If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor. --------- If the above has NO effect it could be that the tube running from the pump cap has the moulding problem and is allowing air in, or is split. you can contact me about this via this thread.
Posted on Mar 21, 2007
I have just replaced my ink cartridges, but now it wont print anything even though it makes the right noises. it whirs and takes the time it would to print something, but the page appears blank.
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink. The printing device consists of a print head and cartridges with ink. When you change the cartridges that does not mean you change the print head, like in some other models. Now you can choose the "head cleaning" option from the printer settings a couple of time. If this does not help you have two options - to get the device to service center or buy a new one. The second option is the cheaper one I suppose. And remember for inkjet printers you must print at least 1 page per week to keep head from clogging with ink. Hope this helps Alex
Sep 11, 2011 | Epson STYLUS CX5900 Printer
Replaced a printer cartridge type 106 with same. Everything was done according instruction. The printer printed several pages and now will not print anything but a blank page. what needs to be done to...
Check to see that the toner cartridge does not still have a "Pull Strip" on the cartridge. or Remove the cartridge and gently rock the cartridge a few times in your hands and re-install.
Jun 25, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
It has printed a checksheet-- with the birds at the bottom. I recently installed new cartridges. It acknowledges a print command by running a sheet a paper through--but it remains blank.
Uninstall and re-install the software for the printer and see if that changes anything. AND also, you say it will always produce a checksheet but anything else is blank? Can you do a simple printer test page? This way you will know if the colors are working.
Oct 09, 2009 | HP DeskJet 5150 InkJet Printer
Dell printer printing blanks pages
? check that you did not leave the pull strip on the cartridge ?
Aug 11, 2009 | Dell Inkjet 720 Printer
Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
May 27, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Printing blank pages from word and now every time canon 6530
There is a service update from Canon, where a part needs to be change in the laser area. You can try to slam the toner door shut to see if it changes it temporarily, but a laser shutter arm needs to be changed.
Mar 25, 2009 | Canon MF-6530RF Factory Reconditioned...
Lex-Z25 Blank Pages
need to install my Lexmark Z25 to my laptop.recently upgraded to windows XP
Jan 05, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Prints Blank Pages
i was having these same exact problems then i looked at my old ink cartridge and saw that the blue tape was off and that i hadnt taken it off my new one i was trying to print with.!!!
Sep 19, 2007 | Dell A960 All-In-One InkJet Printer
Printer wont print anything in colour
Printer nozzle dirty/clog. Need new color ink. Goto printer menu and do the printer cleaning application there.
Aug 04, 2007 | Canon BubbleJet i550 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
97 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
