Question about Mitsubishi WS-65513 65" Rear Projection HDTV
My tv mits. model no:WS65315 indicates no problems with the power
No power up but indicates no problem with the self diagnostics test
    Master:
  • 479 Answers
If the unit does not have power .the connections needs to be checked as something is definately short or loose for sure in the board of the unit.
Posted on Dec 15, 2008
    President:
  • 1,314 Answers
Can you explain your problem further? How can you do a self diagnositcs if it won't power up?
Where does the 12v source in a ws65315 mits tv originate from that drives the h drive chip at pin 9
From the voltage supply board, it is where the wall pug wires are connected inside the unit.
Nov 04, 2016 | Televison & Video
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
Jul 04, 2016 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
Wen i press the power button the tv does not comes on and the light on the power button keeps blinking red
This is usually a self diagnostic indicator. the number of flashes indicate the problem. Without knowing the model number and number of blinking lights it is hard to answer correctly. (Different manufactors have different error codes) Once you get the the number of blinks ...go to google and enter the TV model number and the words "error codes". You should have no trouble finding them.
Sep 09, 2011 | Televison & Video
I have a Mits WS 819 65". The tv only turns on
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have Mitsubhishi HD 1080 model number WS65315
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 19, 2010 | Mitsubishi Televison & Video
I have an Hd 1080 series one day i was watching tv and the volume just went up on it's own i couldn't turn it down and eventually i turned it off> since it hasn't turned back on at all. if i unplug it...
Are you saying the power light blinks constantly and does not stop blinking?
The model you have indicated does not flash light three times on its own.
Confirm model number and I will try to help you--WS65315 is the correct model number?
The more you tell me the better I am able to help you.
SD TECH
Feb 16, 2010 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi ws65315 tv
try accessing the self diagnosis feature by pressing both the menu and device/input button in together on the front of the set and hold for 6 seconds to see if the led will blink a two digit code such as two blinks slight pause then another series of blinks to indicate the second number then let me know the code and I will assist you.
May 23, 2009 | Mitsubishi WS-65315 65" Rear Projection...
My tv willnot turn on
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
MITSUBISHI TV STOPPED WORKING
If you can do self test diagnosis, read threads here on Mits, or goto ctechnicians.com
Dec 16, 2007 | Televison & Video
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
13 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
