Question about Uniden BC72XLT Handheld Scanner
Bc72xlt-no audio/sound/ kids pressing buttons then no sound
Adjusted squelch/volume per owners manual still no sound
  • 31 Answers
The best I can tell you is try readjusting the volume and squelch again. Turn your volume up then adjust the squelch all the way one way and then all the way the other way. At one of the max settings you should get static noise. This should allow you to see if there is any noise coming out of the scanner.
If you get noise then recheck to see that the scanner is programmed correctly. If it has no frequencies or frequencies with no traffic on them, you will not hear them.
If there was no audio with the squelch then you may want to consider that there is a bigger problem. Page 53 in your manual describes how to reset your scanner. This might work as a last ditch effort. You will lose all of your current programming though.
Hope this helps
elijam1
http://www.scannermaster.com/?Click=37131
Posted on Jan 08, 2009
Set clock on a jvc kd-r330
It's very simple even if you don't have the owners manual.
Step 1: Hold in the Menu button until "DEMO" shows on the display screen.
Step 2: Scroll with the volume knob until it says clock. Then press the volume knob to select it.
Step 3: Scroll with the volume knob until it says "CLOCK SET." Then press the volume knob again.
Step 4: Then adjust the hour first by scrolling with the volume knob. Once the correct hours shows press the volume knob and it will move on to the minutes.
Step 5: Once the hour and minute is chosen push the menu button again to finish the procedure.
Nov 13, 2013 | JVC Kdr330
How do I adjust squelch. Squelch is locked on
I suspect you have it in the continuous monitor mode so follow the directions for getting back into the automatic squelch mode.
AUTOMATIC SQUELCH: The FRS is equipped with an automatic squelch circuitry filtering out weak transmission and unwanted noise, usually caused by terrain conditions.
MONITOR:
- This feature turns off the automatic squelch feature, either momentarily or continuously. It helps in receiving signals to its maximum range, but may pick up static signals, too.
Momentary monitor:
- Press the MON button; the monitor symbol will appear.
- Release the button to restore the automatic squelch.
Continuous monitor:
- Press the MON button for more than 2 seconds until a beep sound is heard. The monitor symbol will appear.
- To restore the automatic squelch, press and release the MON button again.
NOTE: You cannot transmit when the Monitor feature is activated.
This comes from the manual I found on-line at:
http://www.michaelknows.com/electronics/walkie-talkie-manual/
Oct 26, 2013 | BellSouth 1011 (14 Channels) 2-Way Radio
No sound when recording a video
in menu, you will sele sound memo, and adjust the volume.when your record your must press func/set button, you will get sound.
read your owner manual very well.
God bless you
Sep 27, 2012 | Kodak EasyShare V1003 Digital Camera
I have entered a few frequencies into my scanner and now i am trying to get them to scan. I press the scan button and it will scan a channel one at a time, but i would liek for it to scan all the...
Your BC72XLT SCAN feature samples one frequency/channel at a time, but it should only stop on active frequencies. If it's stopping on inactive frequencies you may need to adjust the squelch. For more details on programming and operating your scanner you can download and print the factory manual, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Listening in since the 60's
Apr 20, 2011 | Uniden BC72XLT Handheld Scanner
I don't know what buttons I can press to adjust the volume of my Toshiba Satellite C650. I know how to adjust it by clicking, but that's too slow. I need to know keys I can press to change the audio...
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Dec 18, 2010 | Toshiba Computers & Internet
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
I have a Uniden BC72XL scanner and cats knocked it
In your manual, if you have one, if not look it up on the internet. There are ways with all these types of communications, to reset to manufacturer and factory settings at time of new purchase. Then proceed forward in programming.
Feb 15, 2010 | Uniden BC72XLT Handheld Scanner
Cobra PR4750WX - how do I adjust squelch?
You are right there is no adjustment. You can however turn the squelch off and this maybe what is happening to you.
To turn the squelch off you press and hold the button that is just below the push-to-talk button for at least 5 seconds.
To turn the squelch back on, you either press (less than 5 sec.) and the same button or change channels.
When talking with a specific party or group, you should use the tone coded squelch (CTCSS) and that will mitigate the noise if you are not already doing that.
Apr 18, 2009 | Cobra 22 CHANNEL 2-WAY RADIOS
How to scan frequencies quietly
Yes...adjust the squelch control. This is usually a knob adjacent to your volume control. This should eliminate the static noise and you will only hear audio when someone is transmitting.
Nov 17, 2008 | Uniden BC72XLT Handheld Scanner
GT400 CD DECK
Press and hold the volume knob to get into the setup menu. Press and release the knob repeatedly until you see "Clock Adj". Push the DISP button, then turn the volume knob to adjust the hours. Push DISP again then turn the knob to adjust minutes. When you're done, press the volume knob again. You can download an owner's manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT400®ion_id=1
May 26, 2007 | Sony CDX-GT400 CD Player
Uniden BC72XLT Handheld Scanner Logo
306 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
