Question about Lasonic DVD-3200 DVD Player
Dvd player my lasonic dvd player was moved into a different room. it is hooked up the same way, the blue screen comes on, it says loading for a minute,,,then says no disc. there is a disc in it so what is the problem
2 Suggested Answers
  • 102 Answers
SOURCE: I have a lasonic portable dvd player. When I plug
look for a switch to select DVD or Monitor or IN OUT
Posted on Dec 04, 2009
  • 734 Answers
SOURCE: my lasonic dvd player model
Humidity problem resulting in moisture on the circuits. Drying it out makes it work. Store it in ziplock bag if it was in working condition to avoid moisture on rainy days.
Posted on Mar 11, 2011
0 characters
1 Points
Disc says loading and goes no further
First try different DVD discs. All players of DVD or CD are likely to fail in this way over time. You can try to clean the lens inside the unit, but it may not fix it. Its wise to buy the cheapest replacement, because they never last much longer than a year.
Dec 15, 2013 | Initial 5820 Portable DVD Player with...
I plug the DVD player in and then the screen flickers then nothing
I have found that sometimes the wiring harness comes loose from the main board. The player must be dis-assembled in order to access the main board and display board, you may find the plugs have not been properly seated from manufacture and just need to be inserted to hopefully get your system working.
Jan 19, 2011 | Lasonic PDL-305 Portable DVD Player
Dec 04, 2009 | Lasonic DVF-982 Portable DVD Player...
I keep getting a Bad Disk error when loading DVDs that I know are fine. When there's no disk loaded, all I see is the blue load screen with the message "loading" in the upper left
there is a ribbon cable in the DVD player that connect the moving laser head to the main circuit board. When this cable becomes damaged from moving over time, it will claim that your DVD is bad (even though it is not). Best to scrap the player and buy a new one.
Oct 07, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD Player connection to the tv... Theres three different colours on each side (red, white, and yellow) I already got it hooked up to the tv but the problem is that to hook the other end into the DVD...
Red is usually the left channel audio, white the right channel audio, and yellow the video. Look for something to the effect of "audio out" and "video out" on your DVD player.
Jul 07, 2009 | Norcent Technologies E-DVKIT003 10.2 in....
Can't find the remote
try getting an universal remote it come with a code book and you should be able to program it to work with your dvd player
Apr 27, 2009 | Lasonic DVD-3200 DVD Player
Portable dvd wont play movies
I was getting the blue screen and open, then a black screen after loading the disk. If you have the AV switch in the wrong position, it will do the same thing. My kids must have moved it on me.
Apr 10, 2009 | Memorex MVDP1102 Portable DVD Player
Problem loading disc
just open the loader and replace the lense.
Jul 23, 2008 | Dynex DX-PDVD7 Portable DVD Player
Hook up
My workaround for this was to use the Composite output (yellow video, red/white audio) out from the DVD player and put it as input into our VCR.  You can then use a coax output from the VCR into the tv.
If you don't have a VCR then I'd go to Radio Shack, Best Buy, Circuit City, etc. and see if they sell any adapters or converter boxes
Sep 02, 2007 | Lasonic DVD-3200 DVD Player
Lasonic DVD-3200 DVD Player Logo
16 people viewed this question
Top Lasonic DVD & Blu-Ray Players Experts
Are you a Lasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
