Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Leaking green tube that needs to be replaced
A TV technician told me the green tube is leaking and needs to be replaced.  Where do I get the green tube and how do I replace it?
  • 133 Answers
It wont be worth it, when you change 1, it is strongly sugested you replace all 3, and they cost around 200$ a piece, but just so you know, they cant leak, unless you break the glass at the top
Posted on Jan 08, 2009
My tv is blue. no red & green
Please check if the red and green tube have lights.Then if the green and red tube have no lights the problem is in the driver board of your tv.It is a major repair and need to check the repair technician.
Jul 06, 2011 | Zenith Televison & Video
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Dec 09, 2009 | Hitachi Televison & Video
There is an oil leak somewhere at the tubes dripping at the pcb's. Was told by the technician that the pict tubes has to be replaced.
Wait, there are no picture tubes in an DLP set. This diagnosis cannot be correct. I would consult another service center for a complete diagnosis.
If you have further questions, please respond to this post. I might be able to help you if I knew what your symtoms are.
Thanks for using FixYa
asnowman
Oct 07, 2009 | Samsung DLP HL-P5663W 56" TV
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony Wega kdf-50E2000 Keeps turning off and on
Before you replace the lamp I recommend trying to clean/dust the lamp component and lamp plug in area. I had the same problem and was able to resolve it by simply blowing the dust off the lamp components and fan. Use a can of high pressure air to get into the cracks and crevices.
Jun 04, 2009 | Sony KDF-50E2000 50" HDTV
I paid 9.95 for assistance and did not get a responce but charged
From your description it sounds like G2 voltage on the green picture tube is too high.
Are you confident about adjusting it yourself? There are high voltages in places which can kill. I will not take any responsibility of you getting an electric shock so I suggest calling in a qualified TV technician.
Any TV technician should be able adjust this voltage and it should not take long to do it unless the cases are hard to remove and hard to access the flyback transformer where the G2 (screen) adjustment is located.
Otherwise it may be a faulty green picture tube and this is expensive as you need to get the tube replaced.
Hope this helps
Nov 21, 2008 | Televison & Video
Need new green picture tube
If the repair center is an authorized Samsung service center, they should be able to get hte part for you. I don't have parts listings for Samsung sets, but the part numbers should be available from Samsung directly. Since you know the problem, try another service center that is associated with Samsung. Not all independent servicers can get parts from all manufacturers.
Dan
Jul 09, 2008 | Samsung PCL5415RB 54" Rear Projection...
You dont need a new tube. What you need is to repair the seal on your old tube and replace the CRT coolant fluid. There is a coolant chamber attached to the tube with long bolts with springs on them that contains coolant to prevent your tubes from getting hot. Yours may just need tightening, but I would replace the seal just to be safe as thecoolant can and will destroy your circuit board if its allowed to continue to leak on it.
Jan 15, 2008 | Samsung HCL4715W 47" Rear Projection...
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
