Question about Toshiba WRC 1000 Wireless Cable/DSL/Ethernet Router
I needto know the ip adress to get into the log in the page and it is for a toshiba router
    Scholar:
  • 93 Answers
Click Start Run and then type CMD then OK
From the command prompt, type 'ipconfig' to run the utility withdefault options. The output of the default command contains the IPaddress, network mask and gateway for all physical and Default Gateway
note i down and in the address bar of internet explorer type the Default Gateway it can be any thing usually it is like {e.g. 192.168.0.1}
it will open the router page
Posted on Dec 15, 2008
  • 30 Answers
Hi there, try one of these... 192.168.10.1 - 192.168.0.1 - 192.168.1.1 - 192.168.2.1 Think the first one is yours... manual is here...http://209.167.114.38/support/Download/files_Downloads/Index/WirelessProducts/wrc1000en.htm
hope this helps
I forget my password
Check for the "reset" button on the back of your router. Push and hold that button for 10 seconds.
Please be aware that resetting the router will lead to the loss of all settings, included the broadband connection settings.
Jul 27, 2011 | Computers & Internet
Hi! I tried to access to my Zyxel p660hw d1 with the common 192.168.1.1. ip adress in internet explorer, but it doesn't seem to find the router log in page... Ho can i access to it then?
Be sure that your router adress is 192.168.1.1 you can use winipcfg in windows (the gateway address is what you are looking for) to see if its the good adress.
http://support.microsoft.com/kb/141698
If its not working use another browser, simply restart the router or Hard Reset the router with a paper clip.
Mar 14, 2011 | Zyxel P660HW-D1 Router
I have forgotten my security key and need to obtain it to set up a new wireless printer. I know my router IP adress
you will need to enter your routers IP in your web broweser (example: http:192.168.1.1)
Log in to your router and reset the wireless security password to something else.
The default login for most routers is;
username: blank
Password: admin
Or some combination of the two
~kenjiFox
Jan 07, 2011 | Computers & Internet
My SBG900 router's NAT type is set to moderate when checked on xbox live connection, I tried typing the IP adress into a web browser and can only get to the log-in page, I read that the log-in is naturally...
Try user as "admin" and passwords as "admin" or blank or "password" or "1234" then check. If still not able to access then you need to RESET it. For that press RESET button for 10 seconds reset button is in the back side of router. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 03, 2010 | Arris SURFboard SBG900 Wireless Router...
IP adress is gone
Computer off. Try unplugging your router or modem from power. Wait two minutes. Plug it back in. When it has reset, turn your computer on.
May 10, 2009 | Computers & Internet
Cant obtain ip adress
Have you set up your lynksys to allow wireless QoS? If not go to your lynksys broadband wireless software. If you don't know how enter 192.168.1.1 into your explorer bar, log in with lynksys, default is top line blank password 'admin', go to Applications and Gaming tab and enable Wireless QoS, you'll also see all of the places to establish and open ports for specific applications.
May 09, 2009 | Linksys WRT160N Wireless Router
Internet connection failed but IP address obtained.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Toshiba WRC 1000 Wireless Cable/DSL/Ethernet Router Logo
219 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
