Question about Garmin StreetPilot C330 GPS Receiver
GPS Cannot locate satellites.
This question has been asked by others before but no solution has been offered.
The system had been plugged into the car for a long time, sometime hours, but the statement keeps saying that it cannot locate satelites. I just updated the system on the computer but haven't tried it out to see if this corrected the problem. Do you, in your considerable tech know-how think that this will solve the problem?
  • raylinko
    raylinko Dec 18, 2008
    This is raylinko. I think updating the system on the computer solved the problem.
I had a similar problem. My neighborhood is in a heavily wooded area. I bought an external antenna, connected it and now locate sattelites with no problems
Posted on Dec 17, 2008
Can't locate satellites. ask if i'm indoors
Common problem. Please see this link for more info. Too much info to retype here:
- Jim
Jun 14, 2011 | Garmin Nuvi 350 Car GPS Receiver
Says loooking for signal - even when plugged into car charger - could it be the gps battery
Being plug into a car charger (or wall charger) has little to do with not finding a GPS signal and this apply to your gps battery as long as you get power to your receiver.
It is not unusual for GPS to have problem finding suitable Satellites signals especially inside a building or areas where you do not have a clear view of the sky above you and the unit (e.g. High Rise buildings).
In order to speed up the location of satellites signals, you need to update your unit A-GPS Satellite locations database on a regular basis via 'Tom Tom Home' (which should be installed on your PC or Laptop). You can download the latest version of Tom Tom Home from the official site.
Without A-GPS and the unit not being in regular use, your unit may take a very long time to find suitable satellite signals. My own TomtOm One, without an up to date a-gps database has taken over 15 minutes to locate the required signals even in a relatively 'open' air location!
Hope it helps and clarify the issue.
Jun 12, 2011 | Tomtom ONE GPS Receiver
Rino 530 keeps loosing signal was hunting in Canada using rino while walking . keeps saying no satalite
The GPS needs a clear view of the sky and at least 3 or more satellites to get a fix on your position. If you are under a heavy canopy of tree cover / brush, it can affect accuracy and even the GPS's ability to get a fix at all. Also, if you are in a mountainous region, the geometry of your location and the location of the satellites over the equator could be obstructed, resulting in the lost satellite messages. You must have an unobstructed view of the southern sky to get a fix.
If you are able to get a fix in an open area, the GPS is able to do its job, but the location you're trying to use it in is offers too much interference to capture satellite signals.
Making sure you've got the latest firmware from Garmin can solve a lot of troubles, too. If you still believe that your GPS isn't working the way it should, contact Garmin Support.
I hope this helps - and good luck. Please rate my reply - thank you.
Feb 23, 2011 | Garmin Rino 530 GPS Receiver
GPS can not locate satellites.
Where did you try this? GPS signals are "line of sight" only and will be blocked by even thin metallic coatings. Some high-end european cars have window coatings that block GPS signals.
If the unit is new, it may take it a long time to get its first fix, It trys to look for the satellites it thinks it should see at whatever location it last was and at whatever time it thinks it is. After it first locks on to a satellite, it will eventually download new ephemeris data and correct itself, but this may take a while.
make sure you are trying this outside where the GPS has a clear view of the sky. You can go to the system settings page and set your location and time and that will help it find satellites quicker than it would if it thinks it is somewhere else at some other time.
If you still can't get satellites, you may have a bad internal antenna or receiver.
If you have already tried what I suggest, contact Garmin for their free technical support. and push the support button near the top of the page. There is both phone and email support.
Oct 01, 2010 | Garmin Nuvi 660 GPS Receiver
My tomtom one gps can't get signal
When was the last time you updated the QuickFix of your TomTom? It helps your GPS to find the satellites.
Please, do the following:
1) Install "TomTom Home" software in your computer from
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Be sure you choose to update "QuickFix".
Please, report back if you need further assistance
My ID: alexocuello_
Mar 19, 2010 | Tomtom ONE GPS Receiver
My 2620 won't acquire satellites.
These are tough sometimes, you have to be in a open area, not alot of trees. The unit will get satellites better if it is plugged in rather than on battery. If the unit still does not get satellites then it has to be that the satellite coverage in your area is not that great.
Feb 03, 2009 | Garmin StreetPilot 2620 GPS Receiver
Abnormal Powerdown Error Code
Your battery is dead, which is causing the problem with "slow to receive satellites". Normally when you turn off the unit it will remember the last location and time, then the next time you start the unit it already has the time and current location to acquire satellites, but with a dead battery it has to start from scratch. Check the screen and see if it says "Locating Satellites" or "Acquiring Satellites". Locating satellites will take longer. Replace the battery and your problems should go away.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
