Question about Coleman 10' X 10' Sundome Tent 9160K101
Need instructions for Dial Temp catalytic heater 513K
I have a new catalytic heater- new b ecause it hasn't been used but old because it is like from 1961. My problem is that i don't have the instructions to make it work and that is what i would like to know - can i get instructions somewhere so i can use this heater to go ice fishing? Thankyou fo ryour help. Gilles Landry
Manual for a 513 Coleman heater
Coleman Camping Equipment CATALYTIC 513 HEATER ...
Question About Coleman Camping Equipment CATALYTIC 513 HEATER. Need the instruction manual... This item uses Coleman liquid camp fuel. Asked by ...
? 6:35
Oct 6, 2013 - Uploaded by Nomad-76
In this video I provide a detailed look at the Coleman 513-700 Catalytic Heater Useful link: www ...
Jan 12, 2016 | Coleman Heating & Cooling
Where do you turn the water temp up my electric water heater moderl SE50M12AAH
Behind a little cover at top & bottom of side of water heater. you will see the thermostat. Use a flat blade screwdriver to turn the dial to desired new temperature.
they will look like the pic below.
Feb 24, 2015 | Water Water Heaters
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
Sep 07, 2013 | Water Heaters
No heat in car replaced temp control, heater core works is there a flap between the ac/heat ? if so is it located under dashboard?
Did you buy this used? If so the heater core may be bypassed. There should be a flap that changes how the air flows. If it hasn't been bypassed you should be getting heat even if it is still in the ac mode.
Oct 06, 2012 | Cars & Trucks
Whats considered normal temp 99 deville
Most temp gauges are set up to where the mid-point on the dial is normal operating temp. If you were told there is a bad head gasket, and this hasn't been replaced, then that is likely your issue.
Jun 07, 2012 | 1999 Cadillac DeVille
I have a rlp100 heater that works well but now has an annoying smell. It also burns your eyes some. It is 3 years old and hasn,t been used much. What can I do to get rid of the smell?
The smell is unburned propane and the burning of the eyes is caused by carbon monoxide. My heater (RLP100) does the same and I was able to measure the carbon monoxide at 95 ppm (deadly). I have yet to figure out what exactly is happening. Tried a new regulator/hose from a new unit - no help. Also pulled apart the burner nozzle and cleaned the holes - helped a bit. Next step is the valve.
Dec 18, 2010 | Reddy Heater RLP100 Portable Forced Air...
My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Feb 21, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I need instructions for operating the MG15T heater
Basic ...set to desired heat will turn itself on and off to maintain that temp in room (This is made for small rooms)
Dec 12, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Inside heater temp
some where on the heater lines or by the heater core there should be a gate valve. However is your heater fan fluctuating ( blower motor ) with your R.P.M.s ? if so then check the tension on your altenator belt.
Oct 21, 2008 | 2002 Chevrolet Blazer
Coleman 10' X 10' Sundome Tent 9160K101 Logo
174 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
