Question about GPX C1600 5 in. Portable Television
The cd player won't read any of the discs
I honestly don't know what happened, i went away for just a few months, when i came back the player wouldn't work, the antenae was broken and my adapter for the cable is gone, lol, i guess i left it in bad hands, but i took it to get fixed at a repair shop and the guy said it would be cheaper to buy a new one, but i paid so much for this one and i love the way it used to work, can anyone help?
    Sergeant:
  • 250 Answers
Your cable problem I can't help with. The antenna is fairly easy... you just need to replace it with a second-hand one preferably from an old radio that is no good. Just make sure that it is the same size where it screws into the unit. The CD is the easiest part of the lot to fix, contrary to what Repair shops tell you. I don't think these people are dumb, and I don't think they intentionally try to rip us off by selling a new item instead, but I have found that cleaning the lens in the CD player fixes the problem. I buy old CD players that don't work, and within two minutes they are playing again. First try to use one of the commercial lens cleaners. I'll be really surprised if this works , though. It usually takes a LITTLE more effort than that... but that is the quick and easy way, and it's best to try that first. If it works OK, please let me know. I'd be interested to find out. If it doesn't, it means you will have to open the case, and clean the lens by hand, using a soft cloth, and what is known in Australia as Methylated Spirits, and then wipe it again with a soft dry cloth.I don't know the Yankee version of "Metho", but you should find it if you google it. If you need any more help, please don't hesitate to ask........ Please remember to rate this answer.
Posted on Dec 17, 2008
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Won't start, battery good, starter good, swapped relays and still won't start
Any issues with the ignition switch itself? They are mostly made of plastic pieces. With the exception of the actual cylinder. Also depending on how long you had the battery issue,it may have damaged the alternator. They tend to go hand in hand,unless caught early enough. The alternator gets overworked due to the weak battery.
Apr 23, 2013 | Cars & Trucks
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
I have a RDS stereo and it won't play my cd's. It says player error
RESET YOUR PLAYER AT DEFAULT SETTINGS. SWITCH IT OFF. SWITCH IT ON AND INSERT CD. GIVE THE PLAYER TIME TO READ. DON'T PRESS ANY BUTTONS TILL IT COMPLETE IT'S READING. IT WILL PLAY THE CD.
ALSO CHECK CD'S ARE BRANDED AND NOT COPY FROM COMPUTER. FEW COMPUTER WRITE CD NOT HAVE AUTO PLAY OPTION.
IF PROBLEM NOT SOLVE PLEASE INTIMATE.
Oct 07, 2011 | 2002 Buick Rendezvous
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
Hi. I recently bought a Sony CDP-CX355. Until a few days ago it was working fine. Suddenly, the player stopped reading the discs. It grabs a disc as if its going to play it, but just reads it, and then...
This happens when your laser is not able to read the data of the disc. Either u are using disc which the player cannot read or the disc is not readable. If your CD player is not reading the discs which it used to read earlier then CD player laser head has to be replaced.
Aug 14, 2010 | Sony Audio Players & Recorders
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
Jun 13, 2009 | Philips Televison & Video
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Sep 25, 2007 | NAD C541 CD Player
GPX C1600 5 in. Portable Television Logo
151 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
