Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Samsung Bluetooth WEP210 and Blackberry
I'm having problems pairing my Samsung WEP210 with my Blackberry - is this a known problem?
with thanks
  • Anonymous Dec 27, 2008
    cant connet samsung with bb
  • 827 Answers
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Posted on Jan 11, 2009
This worked, except you hold the bluetooth button down until it is a solid blue light on the wep210
Posted on Jan 19, 2009
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
Jan 28, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
SAMSUNG BLUETOOTH WEP210 NEED TO KNOW HOW TO PAIR TO PHONE
Your manual can be found here... it should walk you through the connection process fairly easily.
Mar 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
J can't use the bluetooth headset wep210
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Searching for the headset on the phone
4) The phone should search for any available Bluetooth devices and display what was found
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Can't conect headset
you need to hold down the button on your headset until the blue stays on instead of flashing, then the headset has been reset, then try pairing your phone with your headset, and type in 0000 as the password, this should solve your problem :)
Sep 07, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Jun 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth headset
The reason is because the headset onlys pairs once
Nov 09, 2007 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
337 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Greg Cann
Greg Cann
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
